Previous in Forum: ASME B29.22 Diagram of Sprocket Tooth   Next in Forum: Elliptical Gear Manufacturing
9 comments
Torque Calculation of the Roll
09/27/2011 3:24 AM
Hello,
Can anybody help me to calculate the torque needed to rotatte this roll?Approx wt is around 105Kg.
Just let me the equations to calculate the same.
All the diemnsions are in mm and Material is of D2/SKD11.
i need to slect a motor and Gbx for the same accordingly.
Regards,
RR
Re: Torque calculation of the roll
09/27/2011 3:31 AM
What impinges on this roller that might impede its rotation?
(Information thus far is sorely lacking.)
09/28/2011 2:33 AM
Hello,
This assembled on an shaft which inturn supported at both ends by roller bearings.This shaft is connected to universsal joint shaft and which is connected to gearbox and motor.My intention is to confirm some of the calculation i did is correct or not.My end when i calculated i got approx 127 N-m as the required torque. But i considered the wt of the material only as the force.Now i need to know weather need to consider any other factors like Moment of inertia and all to be considered.I f you have any information about the same please do share with me.
Regards,
RR
Good Answers: 181
09/27/2011 6:48 AM
Why don't you just admit you're out of your depth with this pipe roller system?
Re: Torque Calculation of the Roll
09/27/2011 2:53 PM
No. Anybody cannot help you do your job because you do not understand the requirements that must be known to do your job. What you need is not anybody but somebody that knows your job better than you do. Spinning this roller without any frictional load applied can be easily done by even an HO gauge electric locomotive motor. Spinning this roller quickly up to 10,000 RPM to test the uniform integrity of the of the composite material of the roller will take a much different motor and mechanical design. If your roller will be supporting some added mass on the roller that will be moved laterally or vertically then this will also change your drive requirements. Your drive requirements will also depend greatly on the bearing friction added to this roller that are not in your drawing.
Now, do your own homework.
09/27/2011 3:54 PM
All you need is gravity and 3° of slope.
09/28/2011 2:43 AM
if its a retrofit then just test the thing:
Wind a rope around the roller, hang different weights from your rope and decide which weight spins the thing fast enough for you.
Use T=Fr to calculate the required motor torque.
If its not a retrofit then: (please note - this is quess work)
a) Estimate the rotational friction of the system - maybe contact your bearing supplier, they might be able to give you a rotational friction coefficient? - if not search a bit and try to see if you cant find one.
b) Use T=kW where k= rotational friction coefficient and W is your weight (in Newtons) to calculate the torque required to overcome friction.
c) From here on you need to know how fast you need to accelerate the roller (lets call it a (measured in rad/s^2))
d) also you need to know the rotational moment of inertia (do a search - you'll find it) (lets call it E for now)
e) Use T=Ea to calculate the torque required to accelerate your thing
f) Add the two T's (one calculated in b one calculated in e) and multiply by a safety factor
h) Then go and buy the strongest motor your budget allows.
cheers
KPG
ditto
09/28/2011 8:34 AM
As I read the answers to this question, I am struck with the variety of them....and some of them are harsh indeed.
Yes, it's true that the original statement of the problem was incomplete and in order to help we needed more information. But to keep accusing the O.P. of being incompetent in a nasty manner serves no one.
That being said, the problem is really basic college level and engineering physics. Any decent text or handbook will give equations for angular rotation, forces and moments, and plenty of examples. The original post is a classic "text book example". So to the original poster, I would say get out your text books and do a little study....the answers you need are there. If you don't have the textbooks or handbooks or access to them, learn to be more familiar with Google search. For starters, have a look at engineeringtoolbox.com. I think you have all the data you need to make use of basic equations, and remember to account for friction in the bearings, motor efficiency and any other losses the actual system could incur.
To some of the repondents, I will paraphrase what the code of ethics for licensed professinal engineers says: I will not criticize the work of others without first understanding all the conditions, constraints and situations in which the original engineer is working under. Most especially I would encourage everyone to refrain from making comments that are personally derogatotory. The O.P. needs to be encouraged to learn the practices of what engineers do to apply their basic knowledge, not slapped silly and sent on his way. Let's give the guy a break, help him to learn and all be a little more understanding.
09/30/2011 9:53 PM
This is a great reply.
You never know who your dealing with and all the world can see your arrogant posts. Remember to all of you,
The toes you step on today might be attached to the ass you kiss to keep/get your job tomorrow.
The web never forgets. LOL
glenesterline@gmail.com
09/30/2011 10:35 PM
WalMart needs help. Welcome to America the land of the unemployed engineers with student loans. Arrogant posts show weakness of personal integrity. About 86% of you show weakness in your post. Hell do the stats and repost the results( Please ) Show us the truth.
Register to Reply 9 comments
Anonymous Poster (1); g66 (1); KPG (1); lyn (1); pdef (1); ralish (1); redfred (1); TonyS (1); Tornado (1)
