Previous in Forum: busbars   Next in Forum: Missing graphics
Copper bus bars
09/27/2011 9:26 AM
Please suggest me how to calculate the copper busbars short circuit current
And please mention on what basis the short circuit current will be mentioning.
Please give me formula with examples
So it will helps me a lot
I hope will do the needful
Pathfinder Tags: copper busbars
Good Answers: 804
Re: Copper bus bars
09/27/2011 2:37 PM
Despite the helpfulness of the anonymous post with a link to the search function, forums like this are not intended to be used as a substitute for proper engineering by an experienced professional, and by the very nature of your question, you are obviously not experienced enough to be performing this task. So you are either an EE without the proper qualifications to do this, or you are not an EE at all and trying to get free engineering work over the internet, or you are a student trying to get us to do your homework for you, none of which is acceptable use of this forum. Please hire an experienced professional to do this task.
Re: Copper bus bars
09/27/2011 6:32 PM
JR
You simply amaze me how you can extract that much information from a post that has so little to work with.
Re: Copper bus bars
09/27/2011 10:27 PM
I = E/R. No one said what E is; but R is damn near zero, and can be calculated from copper resistivity and busbar dimensions.
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
Re: Copper bus bars
09/28/2011 6:31 AM
REAL careful here.
That referenced thread mostly concerns CARRYING CAPACITY.
SHORT CIRCUIT sizing is a matter of mechanical stress on the bars, imposed by the magnetic and coulomb forces generated" by 'fault level' Currents many times the carrying capacity of the bus.
Factors are: Voltage, Fault Amperes, bracing strength, distance between supports, dimensions of, strength of, distance between, and orientation of bars.
The idea is that the bars are capable of handling those forces. The fault is expected to clear before significant heating can occur.
It's a specialty of switchgear designers.
Most of us have never done it.
Good Answers: 15
Re: Copper bus bars
09/28/2011 12:26 PM
Register to Reply 6 comments
Anonymous Poster (1); JRaef (1); Pragmatist (1); soebfatehi (1); Tornado (1); wareagle (1)
