Previous in Forum: HDD Capacity   Next in Forum: Emitter Base Breakdown Voltage of NPN Used as Zener
800 V, 10 Amps DC FUSES and FUSE HOLDERS
09/27/2011 9:55 AM
I require information regarding HRC fuses and fuse holders, preferably with indicators, for use in a DC circuit operating at 560 V DC. Normal operating current is about 8 Amps. The fuse will be placed after a bridge rectifier. Industrial or Military grade is essential. Members may kindly respond with their suggestions.
Thanks.
Re: 800 V, 10 Amps DC FUSES and FUSE HOLDERS
09/27/2011 10:02 AM
Fuse specilist: Littlefuse , Wickman
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
09/28/2011 12:41 AM
THANK YOU
Good Answers: 58
09/27/2011 10:11 AM
Try a Google search of:
Bussman
Ferraz Shawmut
Littlefuse
Edison
Brush
Cooper/McGraw
Cuttler Hammer
Daito
Fusegear
Efuse
GEC Alstromm
GE
Fuji
GEC English Elerctirc
Kearney
KHT
Westinghouse
Optifuse
Weber
Each of these company's have a website with tech support/sales contact info.
Probably best to go to the source for advice on your particular application needs.
All of of these manufacturers can meet industrial specifications and most can meet military (US) specifications.
Good Luck!
09/28/2011 12:42 AM
THANKS
Register to Reply 4 comments
bravo88 (1); KJK/USA (1); SWAMIJI (2)
