Previous in Forum: Surface Thermocouples Mount   Next in Forum: Installation of Pressure and Temperature Transmitter
Velometer and Accelerometer
09/29/2011 1:32 AM
Please any one can tell me what's the difference between Velometer and accelerometer and there different application and there out puts, if i want to check a velometer how can i check using multimeter ?
Re: Velometer and accelerometer
09/29/2011 1:38 AM
1.) Velocity sensors measure machinery casing vibration and are used on machines
where using eddy current proximity transducers are not practical. Typical
applications include pumps, electric motors, compressors, and fans.
2.) Accelerometers are very effective when used for the measurement of high
frequency vibrations. Supplemental high frequency casing measurements are
typically required for measuring gear mesh and blade pass frequencies.
Good Answers: 70
09/29/2011 1:38 AM
Click →Here←
Re: Velometer and Accelerometer
10/01/2011 7:08 AM
Velometer is for low frequency applications and Accelerometers are for high frequency applications.
Normally these signals are verified by varying their amplitude
These signals can be measured through a multimeter by measuring the Frequency of the AC component of the output signal in Hz.
Cheers,
Shan
dj95401 (1); lmartin (1); Shanivas (1)
