Previous in Forum: ASME Sec VIII Div: 01-Flange Design   Next in Forum: Adding angular velocity
Engine Exhaust Temperature & CFM
09/29/2011 8:58 AM
I really appreciate if technical & smart people in the (Deisel utility) control room if they could share info. I am currently having difficulty with my design with out knowing the parameter values for T & cfm.
I intend to design an economizer or a heat scavenging system for an undergrad paper, I just don't know the range of engine exhaust temperature and CFM/KW rating ratio.
I will be very thankful if you could give me also links for the literatures. Thanks, it is really a great help.
Regards,
Re: Engine Exhaust Temperature & CFM
09/29/2011 10:32 AM
Diesel exhaust 540-650°C. (From Engineers Tool Box)
CFM/KW ratio depends on too many variables. Ask a manufacturer.
We try not to do people's homework for them.
09/29/2011 11:44 AM
Lyn gave you the exhaust temperature. Cfm/kw can be calculated from spec sheet. you know Kw, engine capacity, rpm, number of cylinder, it is a 4 stroke engine,, google the stoicometric combustion equation of diesel and oxygen composition of air, so cfm/kw is a simple calculation.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
09/29/2011 7:21 PM
What size engine are you talking about? Truck and bus engines, especially in Europe, run much cooler than the temps given by Lyn. Some have Tmax of around 300°C.
Google some manufacturers - many of them have engine specs on line. That's how we, who work in this industry get a fair chunk of our information!
Chaos always wins because it's better organised.
bravo88 (1); English Rose (1); lyn (1)
