I forgot my password.
Don't have an account?
Is there any way to add up shafts angular speeds, as shown below, using only gear box.
l
Yes, it's called differential.
Would it be, speaking of angular speed:
"Planet" + "Arm" = "Ring"
I guess I have found the solution ...thanks to your tips.
Using the "tabular method" when all members are rotating, leads to:
where a and b are evaluated from the known speeds of two of the members.
For a differentiel, we can add SUN and PLANET to obtain ARM...The problem here is how to connect a shaft to PLANET?
We can then use a Planetary gear train, with N1=N2 which lead to SUN + PLANET = 2 ARM
