Previous in Forum: Slope of Buchholz Relay   Next in Forum: 38kV to 208V Voltage drop
How to Make My Own 11 kV Ring System
09/29/2011 9:57 AM
the supply authority is feeding me with radially, how do I make my own 11kv ring system from a radial supply and what equipment should I use.
Good Answers: 181
Re: How to Make My Own 11 kV Ring System
09/29/2011 10:05 AM
If you make a ring at the end of a radial you end up with a Lollipop!
Good Answers: 181
09/29/2011 10:56 AM
Will the utility company supply a second feed? If not then there's no point perusing it. Any system is as strong as the weakest link, in this case the single radial feed. If they will supply a second feed they will want strict control of the system so you can't parallel parts of their system.
Talk to a consulting engineer!
08/06/2012 7:14 AM
thanks for effort
Register to Reply 3 comments
