Previous in Forum: Zero setting on Fluke 887AB diff.voltmeters   Next in Forum: Why Circle Squaring Is Impossible
8 comments
Chinese Rocket Launch Site
09/29/2011 2:35 PM
I've just been reading about the Chinese Rocket launch on their space programme. On the BBC it showed the launch site as in the north of the country. I thought their was a great advantage from launching as near to the equator as possible. Has anyone any reasonable ideas as to why they chose the north of the country rather than a coastal site in the south? As an aside, is there a re rule of thumb that shows the difference in cargo weight with the same rocket, if a lower latitude is chosen? I saw a programme a few years ago about the Ariane and they gave a rule of thumb about weight and design. If you can save 1lb through a design change, it would ultimately save 16lb in the final design as everything cn be made that little bit lighter to cope with the reduced final take off weight. Source was the discovery channel I think.
Good Answers: 44
Re: Chinese Rocket Launch Site
09/29/2011 3:12 PM
There may not be any speed/time advantange to launching near the equator for them. Their targets may be more easily reached by brute strength and physically closer distances.
09/29/2011 6:08 PM
Polar orbits are easier to achieve when launched from northerly sites, since there is less eastward velocity to have to counteract. Many weather satellites (and spy satellites) are placed in polar orbits. Polar orbits are also better for ICBMs!
At one time NASA and the Air Force had planned to use Vandenberg AFB for launching the space shuttle into polar or high-inclination orbits.
Good Answers: 44
09/30/2011 10:32 AM
I was thinking more along the ICBM line...it's the military in me
Good Answers: 52
09/29/2011 10:36 PM
Launch from a remote area has the advantage that failure is more easily kept secret. Additionally, it offers less risk of collateral damage upon failure, due to low population and industry density. Further, Western observation satellite orbits are patchy up there.
Mark Bingham
Relativity PL
09/30/2011 12:31 AM
Dear Worrier: --In a word, "DON'T!" lol? Beyond that, I think you're correct, the higher as to altitude, the launch is, the less fuel will be needed to reach escape velocity and beyond. Supposedly, USA launches were supposed to be moved to the rockies in Colorado, but it hasn't happened yet. I'll go out on a limb and posit that it doesn't matter whether the launch is equatorial or not, anywhere can be reached from anywhere, because we have better control of payloads. Of course, it takes less fuel to NOT have to move very much, to be able to use enertia et al, but we have satilites covering every inch of enemy countries to be able to "read" their newspapers, lol. In some cases it doesn't work. We had to use other methods than photos during the cold war, as a certain Russian tank factory was always under clouds, and so output couldn't be counted. Maybe the plant produced...its own "clouds?" The Ariane...WHY wasn't it bigger, and if not bigger, why weren't boosters stuck on its sides like many of the US & Soviet rocketal-"LIFTING ENGINES." Note even the Red Chinese rocket has side boosters, but I can't remember those on the Ariane. It's almost, to me, like the French were whispering, " moi aussi", with the Ariane, rather than a larger than C-5 Saturn/Vostok, saying "Et LA!"
Good Answers: 918
09/30/2011 9:32 AM
Come on. There is very little fuel used to lift a spacecraft 5,000 to 20,000 feet when you compare it to a target altitude of 1,000,000 feet up.
Then there is the cost of logistics to build a spaceport at such a location and operate it under the adverse conditions that rule the site. One large issue is wind.
To put things in perspective, it take the Shuttle 44 seconds to ascend to 20,000 feet. The total burn time for the Shuttle is 8.5 minutes.
Here is the ascent profile for STS-124.
Anonymous Poster #2
09/30/2011 12:31 PM
Why did the Space Shuttle always do that roll?
Good Answers: 918
09/30/2011 1:56 PM
Mainly to relieve stress on the space craft, but it also gives it a slight edge in climb performance.
Register to Reply 8 comments
Anonymous Hero (2); Anonymous Poster (2); cuba_pete (2); Relativity PL (1); Usbport (1)
