Previous in Forum: That Fishy Smell in Water   Next in Forum: Gearbox Manual Required
8 comments
Contactless Torque/Power Measurement on Power Station Gas Turbine
10/03/2011 6:12 AM
I'm looking at doing a project related to measuring power of a gas turbine in a power station. The GT has a lay-shaft between it an the generator and it is the torsion or torque on this shaft that I would like to measure. The lay-shaft is about 2 metres long and has a diameter of about 900mm. The transmitted torques will be of the order of 8MNm. I think I need a contactless torque/torsion/power measurement system e.g magnetic or optical. I would be very grateful for any advice or comments on how this could be done.
Re: Contactless Torque/Power Measurement on Power Station Gas Turbine
10/03/2011 1:20 PM
Is this project for school, or work?
You might be able to measure the shaft deflection over the 2 meters. Maybe rotary encoders? Maybe optically, if you can scrib a fine line on the shaft.
What do you think? Do you have any thoughts on the subject, or just a burning desire to learn?
Good Answers: 19
10/03/2011 11:19 PM
Assuming that the machine does not run constantly, you can bond a stress-sensitive polymer film to the shaft, then illuminate the rotating shaft with polarized light from a strobe light and view the stress-sensitive film with a polariscope. This article may give you more and better ideas.
http://www.vishaypg.com/docs/11212/11212_tn.pdf
Just be sure to stand well clear of this thing when it is running. A shaft that large creates air currents that can suck your clothes, your hair, etc. right into it.
Good Answers: 109
10/04/2011 3:02 AM
GA to post 2.
RJP, please state the needed accuracy and resolution.
RHABE
10/05/2011 9:52 AM
Need to be able to measure a few fractions of a degree, maybe even down to minutes of arc.
thanks,
10/04/2011 4:13 AM
We have already done such kind of project for mechatronic systems. Until now we worked on small torque values, but the principle is a contact-less magnetic sensor that has the advantage to measure the torque even at rest (no rotation) around a rotating shaft.
If interested by a project, you can contact Christophe Benoit in the "contacts" page of the site.
Good Answers: 58
10/04/2011 8:48 AM
The torque induced into the shaft will twist the shaft. The amount of twist is proportional to the torque. 25 years ago the twist measurement would have been made with strain gauge and a slip ring. Today it is done magnetically or optically. You can, for example, wrap encoder tape around the shaft at both ends and bounce a low power laser beam off the tape. The reflected beam will be detected with photo diodes. The phase difference between photo-diode pulses is directly proportional to torque. It's fast inexpensive, and non-contacting.
Location: OZ, otherwise known as Oklahoma were the wind comes sweeping down the plains.
10/05/2011 11:41 AM
Check this out http://www.atitelemetry.com/viewproduct-48939.htm, these people may have exactly what you need.
Good Answers: 130
10/05/2011 8:29 PM
GA
Register to Reply 8 comments
34point5 (1); bubbapebi (1); Grand Poobah (1); lyn (1); Patrick Meneroud (1); RHABE (1); RJP (1); welderman (1)
