Previous in Forum: what is an ideal interior fountain liquid   Next in Forum: Design for Double Eccentric Butterfly Valve
Circumferential Weld on Exchanger Tubes
10/04/2011 3:48 AM
We have to fabricate an heat exchanger as per ASME VIII Div1 U stamp. The tubes are shorter than those required. So we are planning to have a circumferential weld to reach the required length. Is this is permitted by the ASME Code?
Thank you for your help
gmgm
Re: Circumferential Weld on Exchanger Tubes
10/04/2011 11:01 AM
Whether or not it is, can the welded tube still be passed through the holes in the tubeplate(s) and baffle(s) before expanding?
10/05/2011 2:31 AM
Thank you for reply.
no problem with baffles holes.
by
gmgm
Register to Reply 2 comments
