Previous in Forum: ELR Protection for Unbalance Load   Next in Forum: Damage AC Compressor
Induction motor
10/04/2011 5:59 PM
Hi all, there is a problem related to induction motor not taking load, as load fed it go stop, what could be the solution?
purv mistry
Pathfinder Tags: motor
Re: Induction motor
10/04/2011 7:09 PM
You need a lot more information. Motor HP, voltage, load etc.
Good Answers: 244
Re: Induction motor
10/04/2011 8:42 PM
The most probable case is the motor is unable to produce the required torque to run the load. You need a motor of larger capacity for the load.
- MS
Good Answers: 804
Re: Induction motor
10/04/2011 8:51 PM
Or you may have the motor connected incorrectly, i.e. you have connected it in the pattern for a higher voltage than you have. Or you have a bad motor, or you have a blown fuse somewhere, or you have a bad controllers etc. etc. etc.
As was said, you need to provide more details if you want meaningful help.
Re: Induction motor
10/04/2011 11:46 PM
And you should also tell us if this is a real situation, or a project for your engineering class.
Is there more to the problem you haven't shared with us?
Good Answers: 15
Re: Induction motor
10/05/2011 12:08 AM
(1) read carefully the name plate of the motor. note down the current, voltage, frequency and kW?
(2) observe the terminals - are there 6 or 3?
(3) check from your purchase document or manual if it is a 3PH squirrel cage induction motor?
(4) check all the mechanical connections to the shaft and ensure that there is no clutch or brake that is stuck or malfunctioning?
(5) measure the no load current in each line using a tong tester when the motor is running without load (presume from your question that it can be run that way)?
(6) read this . . . http://www05.abb.com/global/scot/scot259.nsf/veritydisplay/bf88560fb1b0335cc2256fc6003e4e05/$file/motor%20guide%20gb%2002_2005.pdf
(7) and this too . . . http://www.advancedfluidsystems.com/files/resources/Electric_Motor_Troubleshooting_(Polyphase).pdf
like suggested by my learned friends . . . tell us more about your motor and application . . . many here will guide you well . . .
Re: Induction motor
10/05/2011 5:44 AM
Is the selection of motor,CB and OL ok?. Is it driven by belt drive,did you check the voltage/current/speed etc at no load and on load?.
pnaban
Register to Reply 6 comments
JRaef (1); lyn (1); msamad (1); pnaban (1); soebfatehi (1); wareagle (1)
