Previous in Forum: SCF   Next in Forum: Resin Embedded Components
Power Plant
10/06/2011 3:35 PM
In a power Plant, generation is at 11 kv .
UAT and GT at 11 side mostly having delta ie same connection type.
Secondary of UAT is 6.9 kv (star)
Can we use star/star ie 11kv star and 6.9 kv star, while 11 kv winding of GT is DELAT????
Re: Power Plant
10/06/2011 3:46 PM
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
