Previous in Forum: Water Hammering   Next in Forum: Wagon Tipplers
Food Grade EPDM Gasket m and y Factors
10/07/2011 6:44 AM
Dear all,
This may have been a repeat question.
can anyone pls tell me what are m and y values for the food grade EPDM gasket?
is the tensile strength value mentioned in most of supplier's advertisement helpful?
Has there been a study by gasket manufacturer's such as Garlock etc. to evaluate m and y values for the EPDM material?
Please help.
Regards
ASD23789
The light of blindness of knowledge is yet to reach me, forget being clever.
Pathfinder Tags: EPDM food grade
Re: Food Grade EPDM Gasket m and y Factors
10/07/2011 9:11 AM
Dear asd23789
Greeting to you
Since the ideal use of the EPDM (Ethylene Propylene Diene M-class) gasket is that applications which not exposed to oils, gasoline, kerosene, aromatic and aliphatic hydrocarbons, halogenated solvents, and concentrated acids.
EPDM rubber is often used in weather seals, and as a source of noise reduction in the automotive industry. EPDM is an excellent source for gaskets or gasket sealing against atmospheric conditions such as sunlight, ozone, wind and rain. EPDM rubber can withstand temperatures ranging from -50°C to 150°C.
So from this applications and according to gasket materials from ASME sec VIII appendix 2 table 2-5-1 we can say the sufficient factors values for (m factor) is ( 0 ) and for ( y factor - design seating stress - ) is ( 0 ) also.
All types of gasket in this table consist of materials like either mineral or other composition which not looks like rubber.
enlightenment is blessing and self-denial is a good recipe
Good Answers: 137
10/08/2011 6:46 AM
Hello blackpanic73
I have an old version of BS5500 (flange and gasket design pretty much cribbed from ASME VIII I believe) and it says for unreinforced rubber (type not specified)
hardness < 75°BS and IRH - m = 0.5, y = 0 N/mm2
hardness > 75°BS and IRH - m = 1.00, y = 1.4 N/mm2
Different figures for various types of reinforcement.
But interestingly there is no reference I can recognise to one of the most common gasket types, compressed asbestos fibre (CAF) or its modern equivalent because of asbestos danger. Do you have any figures from ASME VIII?
10/08/2011 2:56 PM
Dear codemaster
yes i have soft copy of ASME sec VIII - I edition 2004
in this version in APPENDIX - 2 table 2-5-1 you will find more than one type of asbestos materials for gasket and it found in ASME 2007 too but it removed from ASME sec VIII 2010 and replaced by another equivlance materials of gasket.
THESE TYPES OF ASBESTOS MATERIALS IN ASME 2004 & 2007 ARE:
- Elastomers without fabric or high percent of asbestos fiber
- Asbestos with suitable binder for operating conditions
-Elastomers with asbestos fabric insertion (with or without wire reinforcement)
- Spiral-wound metal, asbestos filled
- Corrugated metal, asbestos inserted, or corrugated metal, jacketed asbestos filled
- Flat metal, jacketed asbestos filled
Register to Reply 3 comments
