Previous in Forum: Allowable Nozzle Forces and Moments For Vertical Pumps   Next in Forum: Food Grade EPDM Gasket m and y Factors
Water Hammering
10/07/2011 5:59 AM
sir please explain the water hammering , water hammering causes and its remidies.thanks
Good Answers: 101
Re: Water Hammering
10/07/2011 10:59 AM
"water hammering"
When water is hammered.
"water hammering causes"
Take a hammer and pound the water.
"its remidies (sic)"
Stop pounding the water with your hammer.
Good Answers: 46
Re: Water Hammering
10/07/2011 8:28 PM
Here you go water hammer. This will give you all you want to know.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Re: Water Hammering
10/08/2011 3:36 AM
Dear Butt
water hammering is caused by small droplets of water formed in steam pipelines. when these droplets hit the pipe at elbows or other bends at high speeds, water hammering occurs. Best way to stop it is removing condensates at various locations on the pipelines and other solution may be to increase the temperature of the steam
Good Answers: 137
Re: Water Hammering
10/08/2011 6:22 AM
But what about water hammer in pipes which are only conveying water?
Good Answers: 19
Re: Water Hammering
10/08/2011 11:55 AM
Please take time to read.
Re: Water Hammering
10/10/2011 8:31 AM
Why is water hammer a abstract concept whereas sledge hammer is a concrete noun, although it has nothing to do with sledges?
Register to Reply 6 comments
Codemaster (1); ducon (1); DVader1000 (1); metalSmiths (1); PWSlack (1); shujabutt (1)
