Previous in Forum: Has Anyone Tried IGBT IXGX72N60C3H1?   Next in Forum: 2 Wire Transmitter (Pressure, Flow Etc).
Steam Drum Level Transmitter
10/11/2011 2:24 AM
Hi All,
How to calibrate the steamdrum level transmitter considering the rage is from -350mm ~ +350mm?
Re: Steam Drum level transmitter
10/11/2011 3:18 AM
Somewhere in its programming parameters, one perhaps sets the low value to -350 and the high value to +350. Anything beyond would be an outrage.
Re: Steam Drum Level Transmitter
10/16/2011 3:58 PM
Hi
Drum Levels I have had experence with have a constant head which will give a differential pressure to a transmitter in the order of 0 to 49 mBars this is then feed into the DCU as 4 to 20 mAmps. Also the Drum Pressure is measured sent to DCU as 4 to 20 mAmps. The Level and Pressure has "Density Compensation" calculation which give a corrected value at different pressures
Not sure if that is what you are after ???
