Previous in Forum: Balance 16 Small Hyd Cylinders   Next in Forum: Centrifugal Blower
ASME B16.11 and MSS SP-97 Socket Weld Depths
10/11/2011 3:37 PM
How are the min. socket depths (Dimension "J") calculated/determined in B16.11?
MSS SP-97 also matches up min socket depths with B16.11 and references it, however for any pipe size greater than 4", I am unable to determine the min depth of the socket.
Regards,
-Mark
Good Answers: 11
Re: ASME B16.11 and MSS SP-97 Socket Weld Depths
10/12/2011 8:38 AM
They make socket welded fitting greater than 4"?
10/13/2011 10:54 PM
Hi,
Socket welds are restricted to pipe size 4" by both the code specified, usually Customer spec have more stringent requirements and limit to size lesser than 2", therefore please check Client spec.
Regards, Manpreet Singh
Register to Reply 2 comments
