Previous in Forum: ASME B16.11 and MSS SP-97 Socket Weld Depths   Next in Forum: Air Handling Unit
Centrifugal Blower
10/12/2011 1:20 AM
How i can design a centrifugal blower if the discharge volume and pressure value is available. the discharge volume is 20000cfm and pressure is 3" wg.
Re: centrifugal blower
10/12/2011 1:41 AM
It depends on whether you are in an engineering culture that calculates everything "from the ground up", versus a commercial culture in which you simply look in a catalogue for a blower that meets the specs. Hint: go on line to find what you need.
