I am prototyping a new device but missing the key component. A water pump that will produce around 100 gallons per minute, but only needs to push against approximately 10 feet of head pressure. The unit needs to have a low energy consumption so it is important that it be designed for high volume/low head use. I am wanting to keep the amperage draw within the 5 to 7 amp range or lower using 120 volts. I prefer the pump to have a 1 1/2" or 2" discharge. It also needs to be NSF 61 certified, which is the standard for drinking water.
Sounds like a tall order, however I have located pumps that are designed to circulate water in fisheries and fountains and that sort of thing that have exactly these kind of specs, such as the EasyPro 6100 or 8800, however they are not NSF 61 certified. The NSF part has proven to be the most difficult hurdle to overcome.
If anyone knows of a manufacturer who makes such a pump I would love to hear about them. I have already done exhausting web searches to no avail so now I am turning to forums to try and find help.
Thank you,
Morgan
