Previous in Forum: Honey bees took my cell phone!   Next in Forum: FIFO FPGA implementation
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
SONET vs DWDM for Metro Rings
04/24/2007 8:34 AM
Today's metropolitan network rings use the synchronous optical network (SONET) standard to support full-duplex, high-speed capabilities for voice, video, and data. Dense wavelength division multiplexing (DWDM), often considered next-generation SONET, actually complements SONET by providing multiple protocols and expanded protection options. Which ring topology, protocols, and wiring schemes are best for your application? (User registration required).
The preceding article is a "sneak peek" from Wire & Cable Technology, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Wire & Cable Technology today.
Re: SONET vs DWDM for Metro Rings
04/24/2007 9:31 AM
I like the multiple fibre optic option where there is always some slack in the system. The ring network is ok for big network suppliers where continuity of data transmission is a requirement. It suits a backplane environment. I work at the end of the line.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 50
04/25/2007 12:28 AM
Actually, I tend to think of WDM as a physical layer thing - you can run just about anything over it. While SONET is more like a data-link protocol because of its packetization of data.
WDM is cool because it gives you several channels over the same fiber And while WDM and SONET are ring topologies, they don't participate in any kind of nasty token passing, such as Token Ring or FDDI. Instead, if they use Spacial Reuse Protocol (Cisco PRP), they hit the fiber in the same way Ethernet works CSMACD. However, at the same time, they have a resilient double-ring structure that can compensate for downed links.
Register to Reply 2 comments
