Previous in Forum: Air Receiver   Next in Forum: Boiler Feed Pump Rotor Shifting
India - Member - New Member
Construction of Air Receiver
10/14/2011 8:58 AM
I need to construct the air receiver separately for 1 pneumatic cylinder of dia. 50 mm and stroke 1000 mm. Receiver should have the capacity of to and fro motion of cylinder.
Then how I should calculate the capacity? What are the parameters involved in this? How much factor of safety should I consider (MS Material and it is a intermittent load)?
After construction, how receiver should test for any defects in welding...
When Emotions runs high ,Intellectual wont work
Re: Construction of Air Receiver
10/14/2011 9:33 AM
I think you should leave things as they are, assuming the system is working now.
You do not have the experience nor knowledge to reduce the air supply by 50% and retain a working system.
I agree you should first understand how much air your equipment consumes. Then understand the capacity of your air delivery system.
Till then, further analysis won't help.
