Previous in Forum: 210 MW KWU Design Governing System   Next in Forum: AC Welders
11 comments
Butane Gas Ignition Pressures and Temperatures
10/16/2011 8:00 AM
I need help determining the pressure ratio needed to pre-ignite butane gas in an internal combution engine. Is the compresson speed an issue? I'd rather not use glow plugs to pre-heat the cylinder. The ambient temperatures will vary between 40-80 deg f.
Re: Butane Gas Ignition Pressures and Temperatures.
10/16/2011 12:45 PM
What is "pre-ignite"?
Good Answers: 114
10/16/2011 10:55 PM
wouldn't the question be
spark ignition or diesel?
10/16/2011 11:05 PM
No. It's too off the wall to be taken seriously, and the OP says, "I'd rather not use glow plugs to pre-heat the cylinder."
Good Answers: 130
10/16/2011 11:13 PM
Well it's a bit 'language', but the OP means "the charge" - a bit like small aero engines do. Sort of compression aided by a hot spot ignition.
10/16/2011 11:28 PM
It is inconceivable to me how you can possible infer that from the original post.
You must count mind reading among your many talents.
Reply Score 1 for Off Topic
Good Answers: 130
10/16/2011 11:46 PM
Sorry Lyn
But the question is fairly straight forward. OP wants to know what the compression ignition parameters are for low temperature starting of a 'diesel' running on gas (not the petrol kind)
Of course there is a lot more that he/she hasn't considered, but that may or may not come out later in the thread
10/16/2011 11:52 PM
No need to apologize.
Good Answers: 130
10/17/2011 12:09 AM
10/16/2011 11:11 PM
1. Do you mean the compression ratio required to attain the auto-ignition of butane
2. You can estimate from the polytropic compression equation. Coupled with gas law, we can deduce the following relationship:
T2/T1 = (p2/p1)^m
where m = (k - 1)/k/polytropic efficiency.
k is the specific heat ratio.
3. Auto-ignition of butane = 405 C
4 Use absolute P & T in the above equation
10/16/2011 11:31 PM
Check this Wikipedia link for an article which explains a lot including "pre-ignition" http://en.wikipedia.org/wiki/Engine_knocking
Autoignition of butane is 420 (c) or 788 (f) and like most fuels these temperatures can vary can because of the chemical mixtures. For instance propane is still propane even though it has varing amounts of butane or methane etc.
This article http://www.mech.kuleuven.be/en/tme/research/Thermotech/Contents/2008_Norman.pdf has a lot of information you can use including a formula for combustion ignition which is what I think you may be looking for.
"don't be so open minded that your brain falls out" unknown
Good Answers: 70
10/16/2011 11:48 PM
This sure has the bang of a Home Work Question in Auto-101a
34point5 (3); dj95401 (1); Garthh (1); lyn (4); Randyl (1); sabriahmad (1)
