Previous in Forum: Pressure Vessel Shell to Elliptical Weld Head Joint   Next in Forum: Chilled Water Pipe System
Diesel Firewater Pump Noise Limit
10/19/2011 8:20 AM
what are the allowable noise level for diesel operated firewater pump and which code guide us for it. please reply positive.. thanks
Good Answers: 445
Re: Diesel Firewater Pump Noise Limit
10/19/2011 10:04 AM
Depends upon your location, noise limits tend to vary by local and national standards. Google is your friend.
Good Answers: 179
10/19/2011 11:44 AM
RAMconsult is correct, it depends on the location and local statutes. GA from me!
Try to keep the dB level below 70, either by installing an appropriate "CRITICAL GRADE MUFFLER", or use sound-attenuation enclosure panels installed completely around the engine and pump...this much easier to install for an indoor installation.
Good Answers: 179
10/19/2011 11:55 AM
Oppps sorry, that should have been 70 dB(A), as measured at 7 meters (~21 feet) distance.
Check out the Gillette Generators website regarding their "Sentry Exhaust Silencers". You may want to install a Hospital Grade exhaust silencer...
www.gillettegenerators.com
SENTRY-PRO EXHAUST SILENCERS
10/20/2011 4:22 AM
The noise limits for all manner of things are given in appropriate national standards.
CaptMoosie (2); PWSlack (1); RAMConsult (1)
