Previous in Forum: Pump Running Indication   Next in Forum: Undershoot Calculation
8 comments
Burner Limit Switch Problem
10/19/2011 9:40 PM
Hi,
We are running a conventional boiler (oil fired) with 16 front firing burners.
We are having problems related to air register limit switches open indication.
We have found out that the limit switch cannot withstand the dust and temperrature.
We keep on changing and also eventually jumpering the signal for air register open indication.
FYI, we are using an explosion proof limit switch. Is there anyone in the market that sells heavy duty explosion proof limit switches that can withstand temperature and also a high speed actuator?
Re: Burner Limit Switch Problem
10/19/2011 10:09 PM
Maybe you could mount the limit switches off the the side, on standoffs, or some such way to get them farther from the heat; and then attach extension arms to the registers to reach the relocated switches.
10/19/2011 11:48 PM
Thanks.
One of the problems we faced in doing so is that there is no space.
The limit switch is close to the burner wall.
10/20/2011 12:51 AM
Plan B: Put some thermal insulation in the space between the limit switches and the mounting surface.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
10/20/2011 9:08 AM
You could try using an optical limit switch with remote-mount (fiber optic cables transferring light to and from the electronic switch unit) option. Let the mechanism break the light beam to verify position. Remote mounting solves the heat problem.
As for dust, use a purge air nozzle near the fiber optic lenses to keep them clear of particulates.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Safety - Hazmat - R&D Engineer/Inventor
10/21/2011 8:32 AM
The "flame safeguard system" and "combustion controls" are components that are shipped with the "conventional boiler package" hence for liability sake, this is problem that should be corrected by the manufacturer of the boiler or burner. I would put it on them to correct the problem at there expense and expertise.
masterblaster
10/21/2011 1:36 PM
GA
Safety first. Do not re-invent it.
On the other hand, just for the sake of giving ideas: a flexible steel cable link, that will move with the air register as it opens or close, could be used to actuate a remote switch. this will allow you to get rid of the space problem near the boiler wall (as you said).
Suggest it but get the maker/supplier to approve it.
10/21/2011 12:31 PM
Like Tornado mentioned you can wrap the limit switches in insulation and install some vortex coolers to cool the inside and / or outside of the instrument bodies.
I have seen in some cases where a small box with the sides and back filled with thermal insulation is placed around the limit switch with cut outs for the limit switch arm to go through.
Good Answers: 49
10/21/2011 11:14 PM
Another option would be a static pressure switch (mounted remotely) sensing pressure of the fan discharge.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Register to Reply 8 comments
energygod (1); fadzril (1); LAA_Lucke (1); masterblaster (1); tonykuphaldt (1); Tornado (2); vargaalex (1)
