Previous in Forum: Electrical Software   Next in Forum: Difference Between Oil Soak Pit and Oil Burn Pit
How to Start DG
10/20/2011 8:36 PM
How to start generator .If any generator,alternator flow chat, simulation circuit in net
Re: how to start DG
10/20/2011 9:22 PM
generally but not always ,there is an outside cover over the generator--open the cover--there should be a start switch there somewhere--check you have fuel and push the switch--no start?? try a shot of carb cleaner down the throat>>starts??-clean the carb--worst case scenario--take it to a RV dealer and have the tech give you a quick rundown and/or diagnose the problem--relatively cheap for the education
There are no shortcuts on the road to a great experience.
Re: how to start DG
10/20/2011 10:30 PM
Usually I just read the manual rather than try and model the system.
Good Answers: 58
Re: How to Start DG
10/21/2011 8:45 AM
In addition to what Aseer and JAT mentioned, depending upon the system size and configuration, if wired through an ATS (automatic transfer switch) there should be an exercise switch or a manual run switch located on or in the ATS.
Personally, I would go with JAT's suggestion of reading the manual. Sometimes the easiest and most overlooked solution makes the most sense.
Register to Reply 3 comments
Aseer (1); jack of all trades (1); KJK/USA (1)
