Previous in Forum: Manufacturing Car Engines in India   Next in Forum: After Market Starter
55 comments
"Lumpy" Tires
10/21/2011 12:43 PM
I just bought a new set of tires.I'll not disclose the brand, yet.
Here's my concern. From a stop, when I drive away and accelerate slowly I feel a bumping sensation as if I had very aggressive lugged monster tires on the vehicle. This last for only a few seconds and then disappears completely. There are no visible wrinkles or obvious defects.
Other than this I like the tires. I, more than likely will take them back and have then checked by the dealer.
But, I wonder if anybody has had a similar experience.
Re: "Lumpy" Tires
10/21/2011 12:55 PM
The one time I had a similar situation was when I drove my father in-law's car after it sat unused for several years. Literally the tires had a slight flat spot set in the steel belts. It took about a month of driving for them to not have a bump after starting. Since the vehicle was a gift, I didn't complain.
Re: "Lumpy" Tires
10/21/2011 1:05 PM
I have had a number of sets of new tires from major name brands over the years with factory defects.
The most common one is being manufactured off center from the center axis of rotation. That is they are physically round and balance out perfectly on the balancing machine but if you watch them while they are spinning on the balancing machine you can clearly see the center axis of the tire does not match the center axis of the shaft they are spinning on.
That creates an odd wobbling and shaking feeling at different speeds that the high school level tire monkeys cant seem to figure out. It balances perfect but shakes on the vehicle which is apparently way beyond their and most of their managers mental capacities to comprehend requiring multiple trips to the shop to get it properly corrected with a new set of tires.
Re: "Lumpy" Tires
10/21/2011 1:32 PM
You can always set them up in a lathe and turn them true to the wheel and then rebalance.
Good Answers: 918
Re: "Lumpy" Tires
10/21/2011 1:08 PM
They may be defective or out of round. Go back and have them checked.
If they are defective they can be a safety hazard, so be safe!
Good Answers: 58
Re: "Lumpy" Tires
10/21/2011 1:46 PM
I suspect that:
A: They are new and the tread pattern is still "squared off" (not broken in).
B: Once you have put 500 or so miles on them the "bumping sensation" should dissipate.
Based on your description, my gut says tread pattern is still "squared off".
By all means do be safe and have the dealer check them out for you.
Re: "Lumpy" Tires
10/21/2011 2:33 PM
Thanks Guys,
First, I dont have a lathe with enought throat to accomodate these tires.
The tires have close to a thousand miles on them. All commuting on city streets at less than 45 MPH. I've had them on the freeway at 70MPH with no apparent problems.
The frequency of the thumping cannot be correlated, by me, to the tread pattern. The pattern would produce a higher frequency vibration, I think. My gut feel is that the vibrations are about 1/4 of the tread patterns features. They're 255/70/16 with street tread.
I don't think it's out of round cause it disappears at about 5 MPH.
I'm going to call today to make an appointmment at the dealer next week.
Good Answers: 58
Re: "Lumpy" Tires
10/21/2011 2:48 PM
Please do let us know what you find.
Re: "Lumpy" Tires
10/21/2011 2:52 PM
I just got off the phone with the tire dealer. I'm going in next week to have them inspected. The person on the phone wasn't any help. Not that I expected any.
Re: "Lumpy" Tires
10/24/2011 1:02 AM
Lyn,
I feel with you.
Here, I am ruining all the (pep boys - and not the cheapest) tires after 5-6.000 miles. The car becomes a cakewalk inside. With me, the carcass collapses and you feel it when it is articulated enough by striking your hand over the surface when lifted off the ground. I guess more than 20 pieces on 4 cars.
In 2 cases they even messed up the bodywork of the cars.
Wish a good answer could help you, but I doubt it.
Re: "Lumpy" Tires
10/24/2011 1:49 AM
Thanks,
I wish I could understand what you and JonathanG said.
Good Answers: 70
Re: "Lumpy" Tires
10/24/2011 1:53 AM
Here, I thought it was just me
Re: "Lumpy" Tires
10/21/2011 2:59 PM
I'm not sure how much effort you want to put into this little diversion. If you need something to do, I have a few thoughts:
1) Indicator of some type: Chalk, perhaps... Mark the tires, slowly drive on something that will reveal the witness indicator. This would be a fair amount of dinkin' around, but would might tell you if the tires have a depression that is not hitting the pavement, if there is non-linear tracking (wobble)...
2) Have someone else drive the vehicle... you follow and observe, drive alongside and observe... this may reveal an out-of-round situation that is being absorbed by the shocks at some speeds.
3) I had another, and now I have lost it. Two thoughts per post is my limit anyway.
[edit] While I was composing you put up #8. I remember my last thought:
3) Call the dealer, make an appointment.
Re: "Lumpy" Tires
10/22/2011 10:27 AM
I kinda looked at them yesterday. Didn't see anything. Even if I discovered something it wouldn't keep me from driving it and my appointment isn't till next week.
Good Answers: 125
Re: "Lumpy" Tires
10/21/2011 3:07 PM
One thing that no one has mentioned yet is the lug nuts. If one or two of them are less torqued than the others on a given wheel, you might get exactly what you describe.
Re: "Lumpy" Tires
10/21/2011 3:01 PM
In 2001 I purchased a brand new Toyota 4Runner. I had a similar, but slightly different, tire problem. I would get a bump at low speeds and vibration at highway speeds. After having the dealer check alignment, balance and such, they determined the tires had a flat spot on them. They claim that it's from when the vehicles were shipped over from Japan and strapped down tight on the ship (puts a very high load on the tire for a continuously long time).
Toyota changed them out for a new set and all was fine.
J B
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: "Lumpy" Tires
10/21/2011 3:18 PM
I'm not a car expert... but is it possible you have unidirectional tires? All or some of which are rotating the wrong direction? When you drive the car in reverse to you get the same lumpy sound?
Sometimes my thoughts are in a degree of order so high even I don't get it...
Good Answers: 29
Re: "Lumpy" Tires
10/21/2011 3:46 PM
Just a thought mind you, but as we all know, radial tires develop a sort of memory, hence the rule of thumb that dictates rotating them front to rear instead of side to side to maintain the the general rotational direction. My thought was that maybe this "memory" is being developed in your new tires and will eventually subside. In any case, best of luck! New rubber is getting to be an expensive proposition these days.
Re: "Lumpy" Tires
10/21/2011 5:38 PM
I had the same tires on this pickup for about 7 years. Talk about sticker shock!
Good Answers: 62
Re: "Lumpy" Tires
10/21/2011 8:27 PM
Lyn
I used a less aggressive 'rib' tread for street driving and swore off discount brands after going through 7 tires to find 4 without defects. I was saving maybe $20 bucks and having to cycle through the tire store repeatedly. Side lumps, out of rounds, things you could only see inflated - too much bother.
Then found out there are only about 3 companies that make 70% of the 'brands' and the same defect culling I was doing was what I was paying for.
But long and short - check the lug nuts too.
Good Answers: 70
Re: "Lumpy" Tires
10/21/2011 8:38 PM
It sounds almost like you have ply separation in one or more of your tires.
Good Answers: 70
Re: "Lumpy" Tires
10/21/2011 8:53 PM
Re: "Lumpy" Tires
10/21/2011 10:22 PM
Deja vu, all over again.
Sorry, I couldn't help myself. (hic)
Good Answers: 70
Re: "Lumpy" Tires
10/21/2011 10:44 PM
Oooops, sorry about that! I guess I was still laughing about the title of the tread, I mean thread Sorry Lyn, I do understand your frustrations with Lumpy Tire problems. I had a tire that suffered ply separation, out of warranty of course, that had the same symptoms that you described.
Re: "Lumpy" Tires
10/21/2011 10:32 PM
255/70/16 with street tread?
Crikies, that tire is almost as wide as it is high. You might be hitting something under the car, such as a suspension member or inner fender. I'd check the tires for rub marks. Look on the inside of the tire--rubbing on the outside is too obvious and easy to spot. Look for shiny spots on the fender or suspension.
Did you have such monster tires on it before, or did you just upgrade to a new size?
Life is like a sewer. What you get out of it depends on what you put into it.--Tom Lehrer
Re: "Lumpy" Tires
10/21/2011 11:38 PM
These are standard for my vehicle. Last set was this size,too.
I had a macho-4wheel drive with big tires, these are street tires.
Good Answers: 62
Re: "Lumpy" Tires
10/21/2011 11:56 PM
Dodge 2500 1999 SLT 4wd came stock w/245-75-16's.
Dodge 2500 2007 SLT 4wd came w/265-70-17's.
And many two wheel drives are running 19" wheels to allow use of truck tires
Good Answers: 59
Re: "Lumpy" Tires
10/21/2011 11:50 PM
I had one set of tires with side wall separation problems. Same symptoms. What broke the camel's back, when the second one acted up brutally shaking at highway speeds within a few seconds. The dealer found the 3.rd developing defect, confessed to a bad batch, replaced all four. I easily could have a nasty accident.
Not before, never since, knock on wood!
Re: "Lumpy" Tires
10/22/2011 2:49 AM
Sounds like a shopping cart, many of which are built with square wheels....
Good Answers: 179
Re: "Lumpy" Tires
10/22/2011 8:41 AM
When you go into the dealership that sold you these tires, have the Service Manager and the Technician check the Static Balance as well as Harmonic Balance throughout all speeds for zero up to the speed rating of the tires.
I've found out the hard way after buying a full set of tires that not all harmonic balancing machines are created equal, and that you may have to run them on two or more machines to find out the balance problem.
You may also have to check for out-of-round in both axis with a dial indicator when it's on the balancing machine and hand rotated. The tires may have been stored too long or improperly, or are out of specification...
If you don't get any satisfaction from the dealer, then by all means go up the chain of command and demand a meeting with the tire manufacturer's Regional Director.
Good luck with those tires.
Good Answers: 25
Re: "Lumpy" Tires
10/22/2011 12:03 PM
Did the garage balanced them when new? Idea:
Chalk an even "clock" on the side wall and call out to a watcher when the "bump"
occurs, and have them note the clock number on the floor each time.
This will give you a pretty close area for you or the garage to check.
Hope this helps. jt.
My wife asked me what I was doing? I said, "Nothing."
She said, "You did that yesterday!" I said, "I didn't finish."
Re: "Lumpy" Tires
10/22/2011 12:34 PM
Yes, they balanced them. Balance is not an issue. This occurs when the vehicle is moving at 2-4 MPH.
And finally, it's bumps, as in plural, and definitely not a flat spot.
Back from a test spin. More information:
When the bumping occurs I am going about 2-3 MPH. The vibration seems to be somewhere around 25-35Hz with an amplitude about equal to running over a line of pencils, maybe. If I try, I can keep the vibrations going for what seems like more than a complete rotation of the tire.
It does not happen when I back up, which puzzles me.
Good Answers: 59
Re: "Lumpy" Tires
10/22/2011 1:41 PM
Do not run at 2-4 mph, eh?!?
Many devices have a "do not dwell here" speed range.
Your car may be the unique one, displaying it at such a
low rpm. Other than that?
STOP playing with it. It will go away. (Or I think so)
Good Answers: 25
Re: "Lumpy" Tires
10/22/2011 2:18 PM
Second guess: There is something (weighty) inside the tyre.
At slow speeds it "falls" within the tyre creating a tapping or ribbon beat.
At greater speeds it is thrown to the circumferance and travels such it does
not have time to fall and cause the beating. (centrifugal)
I would consider:
i. someone at the garage is having a joke, or
ii. garage wants to get more money off you for further servicing, or
iii. someone maybe disposed of "rubbish" inside the tyre, instead of the rubbish bin.
Just guessing here naturally. Hope this helps. jt.
I thought my new girlfriend was great. But after nosing through her wardrobe
and finding a nurse's uniform. a French maid's outfit and, a police woman's uniform,
I dumped her..... It's obvious, she can't hold down a job!
Re: "Lumpy" Tires
10/22/2011 4:26 PM
Nope. this is a contact problem, not a fish.
They've gotten all the money they are going to get from me. The tires have a lifetime guaranty, and they stand behind it. That's why I buy my tires there.
Re: "Lumpy" Tires
10/22/2011 5:27 PM
i had a similar problem , traced it to water inside the tyre from a gas station air compressor ,obviously someone didnt drain water out of the air compressor tank.
my symptom was vibration , despite it being a near new tyre
first tyre shop charged me $ 25 " to balance it " , it was still the same
second tyre shop tried to balance it , after half an hour he pulled the tyre off the rim and splash ! , there was the problem.
thats what i would be looking for , as the post above me pointed out , it could be a lug nut or a lead wheel weight inside the tyre , or water.
Re: "Lumpy" Tires
10/22/2011 5:34 PM
Thanks.
Good Answers: 179
Re: "Lumpy" Tires
10/22/2011 4:12 PM
Did the tire technician throw a dead trout inside your tire before installing it on the wheel?
It's an old gag, and I must admit that I have done it to a certain #$$hole 1st Sargent back in '82-ish who liked to bust my chops just because he could and outranked me (I was a Buck Sgt. at the time). We (a few Army buddies of mine and I) got a hold of one the rear tires to his '68 Cadillac convertible and rolled it into the motor pool late one night and got the wheel onto the tire changer and voila! .......ploppp ploppp go in several freshly caught small brown trout....not too small, not too big... It's a good thing he was drunker than chit that night and the following morning because when he jumped in the next morning and zoomed off he was so snookered he apparently didn't notice the slight kkkaaaathunking!!!.
Needless to say over the following several months the thumping and smell drove 'ole Sarge completely bonkers. He couldn't figure out what the noise and smell was from. lucky for us he always brought the car into the motor pool and not a local off-base garage as most of the Privates were in on the gag. We zipped our collective lips and said squat and got a great chuckle out of the prank for nearly an entire year!
Putting a piece of Limburger cheese inside a wheel works equally well....we did that the following year.......he didn't know where the awful smell was coming from. hehehehhe
[BTW, placing a very small piece of Limburger cheese atop the engine intake manifold behind a carb is even better "Gotcha"!!!! ]
Re: "Lumpy" Tires
10/22/2011 4:40 PM
Oh that's wonderfully evil. I like it. (Why do we have only an angel icon and not a devil?)
Good Answers: 62
Re: "Lumpy" Tires
10/22/2011 11:09 PM
Most awesome Off Topic ever!
Good Answers: 179
Re: "Lumpy" Tires
10/23/2011 9:53 AM
I'm glad you guys liked it, and I wish I could lay claim to the elegantly evilness that I had previously posted. One of my Corporals came up with the dead trout idea. Of course I promised him that he could be a part of the gag! hehehehehe It was tremendously funny to hear the Top bitching about his stinky Caddy all year long, and it took great restraint on our part to keep from snickering or even bursting out with a good belly laugh!!!
Yeah, I always wondered why we didn't have a "Devil" emotion-con here? Hello CR4 Admin, ya want to add one please???!!!
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
Re: "Lumpy" Tires
10/22/2011 4:35 PM
I had a tire that needed airing up every so often. I took it to my Chevy dealer. They said they couldn't find a leak. Eventually I was told that it was a bad tire that needed to be replaced because it had a separated band in it. It was not under warranty and they did not even have a tire available quickly for it although they were trying to promote themselves as tire dealers. The car was purchased new from them. My suspicion is that the tire was defective and was bleeding air somehow. I wouldn't know how to prove it. The car is an Aveo with Korean tires. The other three tires have been fine. I only had about 12,000 miles on the car at the time.
I would have your tires inspected by independent dealers, and see if they are OK. A set of tires can be expensive, and you really don't want mismatched tires. I would consider small claims court, if you are not satisfied.
Cold weather can cause temporary bumps because the tire is initially out of round. As soon as the tire warms up it stops.
Re: "Lumpy" Tires
10/23/2011 4:51 PM
OK, I am going to break down, reach ion my pocket and pull out two pennies: as mentioned previously (post 16 I believe, among others) it sounds suspiciously like the belt are having a separation issue (maybe they didn't get enough attention when they were younger). I had a Plymouth wagon in a previous life and was dirt poor (with tinkering I squeezed 17 mpg out of it), so I would pick up tires from a wrecking yard and have them mounted. After I had put on a couple of tires, I noticed at very low speeds that the car felt lumpy. After close scrutiny I determined that it was coming from the rear and had a slight side shift, almost a wobble. I looked at all the tires and closely at the back ones and could never see any issue. Well long story somewhat shorter, I was driving down the freeway one night and heard a high frequency zipping sound followed by a shotgun blast: a steel belt had separated and finally failed catastrophically. I think a belt separation would give you the symptoms you describe and still be able to be balanced. As someone mentioned earlier, they need to mount each tire on a spin balancer and slowly rotate by hand to check for any inconsistencies.
Re: "Lumpy" Tires
10/23/2011 6:58 PM
Most tread separations do not produce the frequency of vibration that I'm getting. The vibes also go away completely over 4MPH.
See post #28.
I just checked the lug nuts and they are all fine. These guys do a post install check with a torque wrench. That tells you if they are too loose, but not too tight.
Most tread separations I've seen are more pronounced and visible.
I've been trying to correlate this to the tread features themselves which are 1" x 2" wide with a 3/16" separation on each side. The interior rows are smaller.
It doesn't seem to happen in reverse.
Re: "Lumpy" Tires
10/23/2011 8:42 PM
jack up each wheel off the ground and spin the tyre by hand to see if you can hear anything tumbling inside the tyre
cheaper than pulling each tyre off the rim right ?
Re: "Lumpy" Tires
10/24/2011 1:03 PM
Some tires are made with segmented molds and the tread pattern can "wander" from side to side as the tires rotate. From 2-4mph the side to side scrubbing could be giving you the lumps, especially if the pressure is set low. I had a vibration problem at very specific speeds with a new set of SUV tires with that condition, which eventually scrubbed off as I racked up some miles. Have the dealer rotate the tire with a fixed reference aligned to a rib of the tread to see if the tread pattern moves side to side.
Re: "Lumpy" Tires
10/24/2011 11:17 PM
I'll just take a wild guess on the brand (which hasn't been disclosed yet):
Les Schwab--now there's a man with a spare tire!
Re: "Lumpy" Tires
10/25/2011 12:16 AM
Les doesn't do Arizona.
Re: "Lumpy" Tires
10/25/2011 5:50 AM
I don't know anything about this sort of thing, so my apologies if this is stupid, but, is there any chance that the tracking is slightly out; the treads are moving out (or in) for a bit until they overcome the stiction, then, jump back to central; before starting again.
Re: "Lumpy" Tires
10/25/2011 8:59 AM
I think, at this point, you know as much about this as the rest of us.
Re: "Lumpy" Tires
10/25/2011 12:17 PM
Oh well I have to apologies for this too: sorry I couldn't resist:-
From "The friends of irony":
Re: "Lumpy" Tires
10/25/2011 1:39 PM
I've had days like this.
Re: "Lumpy" Tires
02/10/2012 5:17 PM
Hello, Anybody here?
Well, I finally had the tires looked at and rotated.
I'll swear, after rotation, I can't make the tires do the cobblestone vibration any more.
Go figure.
Cheers.
Re: "Lumpy" Tires
02/10/2012 10:37 PM
NO! WAIT! It's still there. Sorry.
Just like a cobblestone street.
Good Answers: 38
Re: "Lumpy" Tires
03/05/2012 11:43 AM
Just throwing this idea out there... (anyone feel free to add or destroy this at will as I'm not a car guru).
With as much focus and attention the tires have received (balancing, rotation, etc) with no solution... it seems rather likely to me the problem lies elsewhere... a bad u-joint or the like.
Re: "Lumpy" Tires
03/05/2012 11:57 AM
First remember, I'm an old man. These kids at the shop automatically discount anything I say as rubbish. If they can't see the tire hopping around on the balancer, it's ok to them and the cobblestone effect is my imagination.
This condition was apparent as soon as I drove away from the tire shop. Nothing else has changed.
I have contacted the manufacturer and he says take it back to the shop and have them call the factory when they have the tires off.
Well no tread separation is evident and I haven't had time to spend two hours waiting for them to tell me everything is fine.
Thanks for the input.
Register to Reply 55 comments
Anonymous Hero (1); CaptMoosie (3); ChaoticIntellect (2); cherryvan (1); dgibson (1); dj95401 (4); Doorman (1); edignan (3); JBTardis (1); JonathanG (1); JRiversW (1); jt (2); KJK/USA (2); leveles (2); lyn (15); Nothing is Impossible (2); Randall (2); RDGRNR (1); redfred (4); ronwagn (1); Slow Old Poop (1); tcmtech (1); Tornado (2); WJMFIRE (1)
