Previous in Forum: Plastic Garbage Segregation   Next in Forum: Bending Light
Water Washing During Shutdown
10/24/2011 2:14 AM
The past practice in our LPG processing plant is to use raw water from the fire water system to clean pressure vessels of carbon steels during shutdowns. Although we have not experienced any serious corrosion issues for the past 30 years the internal trays have been observed with rust scales. The process is recovery of Propane, Butane and Naphtha from Associated gas.
What is the best water quality to be used for cleaning pressure vessels during shutdowns. What damge can the raw water cause? Appreciate your expert advice please.
Re: Water Wasing During Shutdown
10/24/2011 7:15 AM
It's not the water that is the problem, it's the stuff in it.
  • What is the pH of this water?
  • Has it had corrosion inhibitors dosed into it?
  • What is the Total Settleable Solids? What is the particle size?
Re: Water Washing During Shutdown
10/24/2011 10:35 AM
Rust has no structural strength, so it is quite in order to flush it out with high pressure water jetting.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
10/24/2011 2:40 PM
Although we have not experienced any serious corrosion issues for the past 30 years...
This sounds like a case of looking for a problem where there isn't one!! If the current practice has worked for 30 years, it sounds like an acceptable practice.
Sometimes my thoughts are in a degree of order so high even I don't get it...
10/24/2011 11:50 PM
You can use the water for hydrotest, cleaning and flushing of LPG systems, but immediately after finishing the job you have to extremely discharge all water followed by drying with pressurized air until removing any moisture, then followed by purging with nitrogen before starting operation of plant.
10/25/2011 9:16 AM
Since the system has been operational over 30 years, the rust could be associated with formation over time inside the vessels not from the pressure washing.
I agree that pH and other factors in the water may help the rust formation, I believe that with rust cleaners and inhibitors and a good drying out it may work out for another 30 years.
Abdel Halim Galala (1); ChaoticIntellect (1); PWSlack (2); vargaalex (1)
