Previous in Forum: Incomer Rating of a Small Retail Shop   Next in Forum: Transformer
9 comments
Switching and Protective Devices
10/27/2011 12:28 PM
comparision of switch fuse unit and fuse switch unit
Re: switching and protective devices
10/27/2011 12:34 PM
The quality of your education and intellect is directly related to the effort you put into it. Do your own homework.
10/27/2011 12:51 PM
tommorow is my exam and i dint find the answer for te same.
its not a homework.
Good Answers: 804
10/27/2011 1:19 PM
Both have the same number of words.
Each term structure contains the same three words; "unit", "switch" and "fuse"
The last word in each term is "unit"
The order of words on the remaining two words is different
Good Answers: 58
10/27/2011 3:06 PM
To further add to JR's comment;
Unit has 4 letters
Fuse has 4 letters
Switch has 6 letters
Here is the formula:
6+4+4=14
4+6+4=14
Good Answers: 804
10/27/2011 6:02 PM
You left off 4 + 4 + 6.
And if we ponder a sequential pattern in those digits alone, the next three digits in the sequence would be 8, 11 and 15.
Good Answers: 58
10/28/2011 8:30 AM
"And if we ponder a sequential pattern in those digits alone, the next three digits in the sequence would be 8, 11, and 15."
Well there you have it
Actually, I omitted 4+4+6=14 because that would have equated to "Fuse Unit Switch" or "Unit Fuse Switch"
Didn't want to create more confusion
Good Answers: 181
10/27/2011 9:12 PM
There is a fundamental difference between a fused switch and a switched fuse in the UK.
But as you're not from the UK it's up to you to look at your local definitions.
Good Answers: 181
10/27/2011 9:49 PM
A switched fuse will usually be only be found in very old gear.
To late for his homework Oh dear what a shame!
India - Member - New Member
Good Answers: 164
Re: Switching and Protective Devices
10/28/2011 4:35 AM
IEC is not easily accessible to students. So, it is not a fair examination question, unless it has been introduced into the syllabus now....
If the fuse is part of the moving system, it is referred to as a Fuse-switch (the 'disconnector' part is left out usually)
Register to Reply 9 comments
JRaef (2); KJK/USA (2); kvsridhar (1); Pundalik (1); redfred (1); TonyS (2)
