Previous in Forum: Chocolate Machine   Next in Forum: Estimating Static Head in Mutiple Discharge Points
How to Calculate Withstand Load of a L-Angle Frame ?
11/01/2011 2:12 AM
Hai dudes,
Pls reply for this question early as possible....
Re: How to Calculate Withstand load of a L-angle frame ?
11/01/2011 2:26 AM
How about some weights and dimensions, the actual configuration, and the magnitude of loads to be resisted?
Good Answers: 179
Re: How to Calculate Withstand Load of a L-Angle Frame ?
11/01/2011 10:13 AM
Sorry, I don't respond to peeps calling me "Dude"......
11/01/2011 6:01 PM
apply like this procedures
supports:
Pipe Line
:- For size 4" sch.40(STD.)
SA-283 Gr. C equ. to ST.37
:- Rack support material
108247
15,700:-
(Ss), Max. allowable stress for support material - (Kpa, (psi))
114.3
4.5:-
(Do), Outside Diameter (mm,(in))
6.02
0.237:-
(tn), Nominal wall thickness (mm,(in))
16.07
10.79:-
(w), Weight of empty pipe (kg/m,(lb/ft))
1000
0.0361:-
(ρ), Fluid density(water) (kg/m3,(lb/in3))
5000
196.85:-
(L), pipe span between two supports (mm,(in))
1000
39.37:-
(Lm), Moment arm length for pipe acting on support (mm,(in))
9.81
32.19:-
(ACC), Acceleration (m/s2,(ft/s2))
Inside diameter of pipe
(d) =
Do-2*tn4.03in102.26mm
Internal fluid weight
(wf) =
(Π*d
2/4)*L*ρ
90.49lb41.04kg
Total weight of pipe
(wT) =
(w*L)+w
f
267.63lb121.39kg
Load acting on support due to total weight
(wL) =
w
T*(ACC)
8613.6lb.ft/s
1190.88kg.m/s
Weight of any concentrated load acting on support
(wC1) =
0.00lb0.00kg
concentrated load weight represent in weight of other pipes supported on cantilever
Moment arm length for w
c1 (LC1) =
0.00in0.00mm
Weight of any concentrated load acting on pipe
(wC2) =
0.00lb0.00kg
c2 (LC2) =
0.00in0.00mm
(wC3) =
0.00lb0.00kg
c3 (LC3) =
0.00in0.00mm
Load acting on support due to concentrated load w
C1 (FC1) =
w
C1*(ACC)
0.0lb.ft/s
0.00kg.m/s
C2 (FC2) =
w
C2*(ACC)
0.0lb.ft/s
0.00kg.m/s
C3 (FC3) =
w
C3*(ACC)
0.0lb.ft/s
0.00kg.m/s
Total load acting on support
(WTL) =
W
L+FC1+FC2+FC3
at mid (assuming)8613.6lb.ft/s
1190.88kg.m/s
Bending moment due to w
L (MwL) =
(W
L/4)*(Lm/1000)
403.7lb.ft297.72N.m
Bending moment due to F
c1 (MF1) =
(F
C1/4)*(Lc1/1000)
0.0lb.ft0.00N.m
c2 (MF2) =
(F
C2/4)*(Lc2/1000)
0.0lb.ft0.00N.m
c3 (MF3) =
(F
C3/4)*(Lc3/1000)
0.0lb.ft0.00N.m
Total bending moment acting on support
(MT) =
(M
wL)+ (MF1)+ (MF1)+ (MF1)
403.7lb.ft297.72N.m
Modulus
(Z) =
M
T/Ss
0.168in
2.750Cm
select the Rolled Steel Channel (RSC) section from structural steel beam tables
S5X10 RSC
RSC weight10.00lb/ft14.88kg/m
Modulus (Z
S) for selected RSC =
1.37in
22.450Cm
check
ZS > Z
Ok
Modulus of elasicity
(E) =
210000N/mm
30457925Ib/in
Moment of inertia
(I) =
1.22in
507802.3mm
Maximum deflection
(ς) =
(w
TL*Lm3)/(48*EI)
0.009in0.233mm
safety ratio
(SR) =
(ς) / L
m
0.0002
check
S
R < 1/360
Ok
enlightenment is blessing and self-denial is a good recipe
Register to Reply 3 comments
blackpanic73 (1); CaptMoosie (1); Tornado (1)
