Previous in Forum: Difference Between CT Magnetizing and Secondary Excitation Current   Next in Forum: Tripping of Compressor While Starting Another Compressor in a Different Building
About Force Calculation
11/02/2011 1:15 AM
Dear friends,
Force = B.I.L
Conductor area does't play any role in generated force????
My Doubt is if
L = 100 meter
I = 10 Amps
B= 1 tesla
with 1Square mm & 0.5 Square mm of area, Will same force generates?????
With regards,
Amith N
Re: About Force calculation
11/02/2011 1:56 AM
Yes, it will be the same force, so long as B, I, and L remain the same.
Good Answers: 170
11/02/2011 4:17 AM
Have you not heard of skin effect? The tendency of alternating current is to concentrate more on the 'skin' or the circumference of the conductor rather than on the core. Hence, irrespective of the cross section, a major portion of the current will be in the exteriors of the conductor. As forces are acting outsied the conductor (either attractive or repulsive) the circumferential current is significant rather than the core current.
11/02/2011 7:00 AM
If you can break the 'B' into equation, you will find the ans.
BNDas
11/02/2011 10:10 AM
DC Current? No skin effect but the force remains the same.
OP: The force ahs nothing to do with the conductor - it is the interaction of the magnets - the flowing current creates a magnetic field and that field interacts with the other conductor's magnetic field/ external magnetic Field and that creates the force.
If you want the stress on teh conductor then of course the crossection and would come in but that is another subject (more on the mechanical side)
Register to Reply 4 comments
Anonymous Poster (1); biswanath.das (1); electricalexpert65 (1); Tornado (1)
