Previous in Forum: Shot Blasting of Structural Steel   Next in Forum: HDPE Pipes in Contaminated Ground Conditions
U Value Calculation
11/10/2011 5:23 AM
Need to calculate the "U" vale of the whole system of roof slab and to find out,whether the U value reaches 0.14W/m2K for the whole system. The whole system include 1. Structural slab (Concrete) 2. Water proofing WPS-B301 (BITUMEN),Thickness 27 mm 3. Fiberglass insulation (Density 112 kg/m3,Thickness 225 mm and K value 0.034) 4. Screed,Thickness 75 mm Please advice me the calculation proceedure
Re: U value calculation
11/10/2011 8:00 AM
Try one of these:
  1. R-Value and U-Value Insulation Calculator
  2. U-Value Calculator
  3. U Value Calculation - Roof Insulation | Foam Insulation | Tel: 0800 ...www.foam-insulation.co.uk/general/u-value-calculation.htmExample Proof of U Value Calculation. Property: Roof = profile sheet steel sandwich with 50 mm of fibre glass insulation. Target U value = 0.025 W/(K•m²) ...
