Previous in Forum: Windows manufacturing machines   Next in Forum: Aluminum Railings
Fundamentals of Mechanical Design and Mechanical Drafting
11/10/2011 6:49 AM
The purpose of any mechanical product dimensions is to convey the manufacturing and supervising the mechanical engineering needs for the end substance. The substance could be dimensioned in several ways and by each procedure we should be able to fulfill same needs of mechanical 2D design services and mechanical 3d design services.
Fundamental steps for mechanical design and drafting services are as follows:
- To know the requirements of the completed mechanical components and its dealings with the subsequent level of assembly
- To work with mechanical design in order to define datum that are dependable with the functions of the final mechanical products
- To define a method of dimension to propose the completed part requirements
- Identifying a tolerance method insures the mechanical product to function overall in the series of manufacturing variability
- Inquiring manufacturing or inspection is completely essential to meet the design objectives
http://www.mechanicalcadd.com
Good Answers: 21
Re: Fundamentals of Mechanical Design and Mechanical Drafting
11/10/2011 7:01 AM
And your point is?
11/10/2011 7:45 AM
The point is a poorly worded attempt at a commercial advert.
Spam; come-on; pitch; hook;
The link leads to a design service.
06/14/2018 6:26 AM
The points mentioned should be followed properly while designing and drafting. Nicely explained all the points.
Register to Reply 3 comments
fixitorelse (1); lyn (1); Raman75 (1)
