Previous in Forum: Limitorque controlled by DDC-100M   Next in Forum: What is the normal life span for a VFD?
PWM circuit diagram with SG3524N
04/26/2007 11:49 AM
hello
who can help me with a circuit diagram of an oscillator using SG3524 to generate a pulse width modulation of a frequency of between 50 and 60Hz. This is to drive power MOSFETs like IRFZ44 or higher one for a dc to ac inverter.
if other details will be necessary i am ready to supply.
Good Answers: 120
Re: PWM circuit diagram with SG3524N
04/26/2007 10:54 PM
Per Ardua Ad Astra
01/18/2008 6:10 PM
Hi
I can help you. But call me on +234 806 698 2900 for negotiation.
Thanks.
Good Answers: 120
01/18/2008 9:10 PM
OK, If you want to create 50/60 herz AC from DC, the best way is a switching PWN waveform synthesizer that uses power fets to create a waveform of the required profile with high frequency 20-100 Khz pulses that insrease/decrease to create the sine wave and are followed by a low pass filter that blocks the highs and let the 50/60 hertz though.
this company makes one
http://www.aplab.com/pcc/ps10-a.htm
some links here may hely you.
http://www.google.com/search?hl=en&q=switching+AC+inverters+%2Bpwm&btnG=Search
Per Ardua Ad Astra
01/18/2008 9:42 PM
i suugest you select other chip fpr your inverter project, they are more better for spwm.
05/16/2010 4:51 PM
Anonymous Poster (2); aurizon (2); cnpower (1)
