Previous in Forum: PWM circuit diagram with SG3524N   Next in Forum: I can't remember my logic or how to avoid a race.
What is the normal life span for a VFD?
04/27/2007 9:52 AM
The fluorescent display on an appliance is starting to fade. The item is 8 years old, and the horizontal sections of numbers are now so dim as to be invisible in a normally lighted room - tops and bottoms of 8's, for example.
Would this be a failure of the display, or component(s) controling the display?
Is this repairable, or is it more feasible to simply replace the display module?
Good Answers: 40
Re: What is the normal life span for a VFD?
04/27/2007 12:18 PM
All the references that I can find typically say "more than 10,000 hours' which translates to about 14 months continuous use.
There are a few patents out there that claim to extend this.
There is also alot of documentation that says the Flourescent displays life is shortened by things such as heat, etc.
Good Answers: 40
04/27/2007 12:21 PM
As far as repairing it, it is not worth the hassle, and very difficult to find an exact match. It is better to replace the whole module.
04/27/2007 2:07 PM
Hello
The VFD is an electron-tube with a filament (cathode), a grid and an anode. The filament generate electrons who are transfered to the anode. The anode is fluorescence, it light up when the electrons hit it. The grid control the flow of electrons, you switch on and off the light with the grid voltage.
This was the principle. In real the filament and the fluorescence will age when you use it. The filament will burn out and the fluorescence will decrease. Thats why the light dim.
Anders
04/28/2007 4:09 PM
Look for any electrolytic capacitors in the drive circuit these often lead to this situation. They dry out and lower the current/voltage.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Register to Reply 4 comments
BrainWave (1); Gustav180 (1); techno (2)
