Previous in Forum: Figuring out the Temperature of an Expanding Gas?   Next in Forum: Can I Substitute 37Mn Si5 With EN8
Sealer for Burmished Concrete
11/11/2011 9:22 PM
Hi we have recently layed a beautiful burnished concrete floor for our new home & decided to pay professionals to come in and seal it .They have used a product called deepseal and have not been very successful with the application it keeps giving an orange peel appearance and uneven look some parts are absorbing while others seem not to be it also now has what they said are called crazey cracks which were not there before i think they have applied this stuff about 10 times and we are getting very concerned our beautiful floor has been ruined does anyone have any ideas on what to do ?? cheers jill
Pathfinder Tags: concrete sealer
Re: sealer for burmished concrete
11/12/2011 4:15 AM
Call Deepseal to find out what's going on; it's their product, so they should stand behind it. With so many layers, you may have to sand down and use a different top coat to get an acceptable finish.
11/12/2011 6:03 AM
Don't let these guys do anything else to your floor. I found deepseal on the web, and it says it is for vertical surfaces only, although I don't know if it's the same product.
Thall is right. Call Deepseal. Also try to find a local outfit that specializes in concrete finishing. The people you hired are not them.
I hate to say this, but unless you don't mind the little crazing cracks, you are most likely looking at getting the floor reground.
Good Answers: 266
11/12/2011 7:31 AM
This product(Deep-seal) was not designed as finish. It was designed to penetrate and react with the cement to form a less penetrable surface to water. Have what's left on the surface remove if it was applied right it's done it's job to seal the concrete.
http://www.solvingconcreteproblems.com/dpsinformation.htm
Re: Sealer for Burmished Concrete
11/12/2011 12:27 PM
Yeah, sue and take it to another level...
http://artisticconcretefinishing.com/
11/12/2011 11:35 PM
I am a concrete finisher by trade, dont allow them to apply anymore coats, I would recomend contacting the company that make the product and ask if they recomend any special products in removeing what has alreadg been applied, otherwise u might be looking at having your new floor sandblasted / surface ground, some cracking is always normal do to shinkage, but if it is excessive (looks like broken glass) you are most likely in for an expensive repair job, unless you can live with the cracks, there is a "generic" product offered at places like carrols distributing, menards, lowes, home depot, literally just called, "concrete sealer" it is designed for sealing floors primarily, it works very well, however it will leave a very light white tint on the surface of your concrete, almost like u spilled milk, only much lighter, more or less see thru, it would do a decent job of covering up the cracks, but they will still be there, ypur other option would be to grind the surface down, and cover it with a self leveling epoxy patch, ardex brand is good, but there are cheaper genarics that are also a good product, all in all, you are probably looking at an expensive repair, any way you could post some pictures for me?
11/13/2011 6:06 AM
Tile it.
Bazzer
11/13/2011 1:54 PM
Ive seen round floor sanders used on floor finish do you like circles.
dsuzmay@gmail.com
Register to Reply 7 comments
Bazzer Englander (1); ds (1); Kalboon (1); kramarat (1); ozzb (1); SolarEagle (1); Thales (1)
