Previous in Forum: 200 MVA Single Phase GT   Next in Forum: Generation of Electricity by Speed Breakers
Regarding Selection of PS Class Current Transformer
11/15/2011 6:20 AM
Dear,
Im using generator differential protection relay CAG-34 of Areva make for genset application (500 KVA DG Set )To order the current transformer of PS class i need to furnish details like Knee voltage Vk , Rct & Rl value.How do i can calculate all this value.i need the formula with example for genset application.Kindly forward all formula to find the values.fault current,constant for relay etc etc.
Regards,
sachin.
Good Answers: 244
Re: Regarding Selection of PS Class Current Transformer
11/15/2011 8:22 AM
Good Answers: 170
11/15/2011 8:32 AM
First of all, 500kVA Generator DOES NOT require differential protection. But, may be, your application is so critical that you don't mind the huge investment.
Well! KneePoint Voltage Vkp > K If(s) (RCT + 2 RL) ,
where, K = Constant of Cushion (generally taken as 2)
If(s) = System Fault Current as reflected on the secondary side of the CT
= Primary fault current / CT Ratio
Primary fault current = Generator Rated Full load current / Generators sub-transient
reactance
RCT = tobe given by the CT Manufacturer
RL = Two way resistance of the cable lead between the CT & the relay (this you should know as you only know the size and length of the cable you are going to provide)
Register to Reply 2 comments
