Previous in Forum: PVA Plastic Available in Paste or Gel?   Next in Forum: Changes in Pipe Sizing in the Main Header - Chiller
Deep drainage wells
11/17/2011 6:23 AM
I want to learn if HDPE pipes can be used for deep drainage wells (up to 70 m depth)
Also is there a manual to calculate the diamater and pressure class of the pipe
Re: Deep drainage wells
11/17/2011 8:04 AM
Go to any pipe supplier web site and you will find the information.
Good Answers: 179
11/17/2011 9:50 AM
ADS, one of the world's largest HDPE pipe manufacturers has load vs. depth of bury tables dependent on the type of pipe bedding and pipe zone backfill, as well as the type of pipe trench configuration, etc.
And yes, if you do a Google search you will find the necessary engineering calculations to determine design pipe loading magnitudes vs. allowable pipe loading mags.
Register to Reply 2 comments
