Previous in Forum: Liquids Resistance   Next in Forum: Transformer Oil Level in Degree Centrigrade
12 comments
Cable Duct
11/17/2011 7:07 AM
Hi All,
how to secure cable in the ducting. the ducting doesn't have hole to tie the cable.
what is the best method to secure cable.?
Regards
Re: CAble Duct
11/17/2011 7:53 AM
Vertical? Horizontal?
Re: CAble Duct
11/17/2011 8:17 AM
No one noticed this when they purchased the trays?
Have you contacted the maker of the ducting and asked them?
Must we do everything for you?
If all else fails drill your own holes. Be sure to buy drills with one sharp end for this.
Re: CAble Duct
11/17/2011 8:29 AM
....and something to turn them with.
Good Answers: 181
Re: CAble Duct
11/17/2011 12:30 PM
Duct tape
Re: CAble Duct
11/17/2011 8:38 PM
Are you certain with only one sharp end? How is he supposed to drill the other side of the conduit? Do you recommend he buys two drills. I think your a drill salesman.
Good Answers: 181
Re: CAble Duct
11/18/2011 2:11 PM
I'm surprised Lyn-Door haven't come up with a double ended drill. If you go for the idea I only want a 20% cut of the profits
Good Answers: 58
Re: Cable Duct
11/17/2011 8:51 AM
What type of duct(ing) is this?
Medium voltage, low voltage, Voice/Data, HVAC??????
Who is the manufacturer?
What is the part number?
Did any installation documentation come with the duct(ing).
Best suggestion and as Lyn responded "have you contacted the maker of the ducting and asked them?"
While I await your reply, I will attempt to consult with the amazing Karnak for answers to your perplexing dilemma.
Re: Cable Duct
11/17/2011 8:56 AM
Hi All,
This ducting is for low voltage,
I have contacted the maker of the ducting and the advise just bundle all the cable using tie, my concern is on the vertical part, because the straight run is about 15M.
Regards
Good Answers: 58
Re: Cable Duct
11/17/2011 10:13 AM
You are correct, 15M is a long vertical span with no support.
Did you voice this particular concern with the maker?
What did they say?
Re: Cable Duct
11/17/2011 3:09 PM
Lyn Quote "If all else fails drill your own holes. Be sure to buy drills with one sharp end for this."
Lyn, you are too much. I was unhappy and now I am laughing. Thanks.
Re: Cable Duct
11/17/2011 3:46 PM
Thank you for the kind words. Glad to see my cynicism is sometimes appreciated.
Location: off the beaten track, not quite whoop whoop nor humptydoo
Re: Cable Duct
11/17/2011 11:32 PM
Are we talking cable ducting, or cable tray? what size cables? How many? Are you running cables, or string? cause string will fall even with a tin can at either end. if you are running 2.5mm 2c+e and it is ducting similar to the pic then i suspect you are thinking too much about the problem.
Everything works out in the end, just not neccessarily how you want
Anonymous Poster (1); Chook (1); JWthetech (1); KJK/USA (2); lyn (2); PWSlack (2); TonyS (2); wareagle (1)
