Previous in Forum: What is the Most Important Thing on Selecting Vacuum Pump?   Next in Forum: Cone-Section Modulus
Ball Mill Girth Gear/Pinion Lubrication
11/18/2011 6:15 AM
can you please assist with the proper lubrication arrangement i can do on the above arrangement and also besides the quick waer rate bon my gears what are the consequences of a poor lubrication system on this arrangement?
Re: Ball Mill Girth Gear/Pinion Lubrication
11/18/2011 7:52 AM
What does it say in the user manual?
Anonymous Poster #2
11/18/2011 11:34 AM
Any Gears for poor lubrication would pit quickly especially heavily loaded ones like your.
What is the size of the ball mill and the RPM?
At our mills usually grease spray lubrication is used. However for lightly loaded ones some high viscousity oil is a possibility.
11/19/2011 12:00 AM
Depending on RPM of the mill, some people uses graphite powder but at low RPM, cardomium compound works well.
Detail of cardomium compound are as below:
Shell Cardium Compound
Open Gear and Wire Rope Compound
Shell Cardium Compound are a range of high viscosity, residual-type (bituminous)
lubricants, which are recommended principally for open gears and cane bearings in
the sugar industry which require an adhesive, high load-carrying product. All grades
are blends of bitumen, and heavy mineral based oils, blended in different proportions
to suit various applications.
Applications
Shell Cardium Compound are recommended for use in open gears operating at low speeds and cane
bearings. They may also be used for lubrication of wire ropes.
Performance Features
Strongly adhesive and resistant to water washout
Good lubricity property
Good Load Carrying Capacity
Good corrosion resistance
Typical Physical Characteristics
Grade 100 150 200 460
Colour black black black black
Kinematic Viscosity
@ 100°C mm2/S
(ISO 3104)
100
150
200
460
Flash Point
(ASTM D 92)
Min 210°C
Min 210°C
Min 210°C
Min 210°C
Health & Safety
Shell Cardium Compound is unlikely to present any significant health or safety hazard when properly
used in the recommended application, and good standards of industrial and personal hygiene are
maintained.
For further guidance on Product Health & Safety refer to the appropriate Shell Product Safety Data
Sheet.
These characteristics are typical of current production. Whilst future production will conform to Shell's
specification, variations in these characteristics may occur.
Advice
Advice on applications not shown on this leaflet may be obtained from your Shell Representative.
09/16/2019 2:21 PM
R.V. distributor engaged in supplying of lubricants and greases for steel industries and other sectors like railways, defense, mining, automobile etc. in India and abroad.
Reply Off Topic (Score 6)
anilj (1); Anonymous Poster (1); Mukesh0861 (1); PWSlack (1)
