Previous in Forum: Space Heater Requirement   Next in Forum: Voltage and Reactive Power Hunting Show in My Power Plant.what Reason Behind
Short Circuit Current for Sychrinized DG Set.
11/19/2011 6:33 AM
We have 6 generators each of 2000 kVA, 415 volt and will run in synchronizing. The value of direct axis sub transient reactant is 13%. According to this the value of fault current on bus will come approx (21*6 =126 Ka). So we need a 125 Ka breaker and a bus or can we use circuit breaker with low breaking capacity and high speed tripping relays?
India - Member - New Member
Good Answers: 164
Re: Short Circuit Current for Sychrinized DG Set.
11/19/2011 11:06 AM
NO! The Circuit Breaker HAS to have a capacity of more than 126kA for SURE. You should be looking at 150kA CBs. These will be current-limiting breakers and will act much before any relay can act, however rapid the relays are. This is known as 'reflex trip'....quite similar to what happens in the human body.
Please study the catalogs of top switchgear companies to learn more about rapid-trip circuit breakers.
11/19/2011 10:27 PM
Good Answers: 170
11/20/2011 10:04 AM
Go for solution given by KVS! Alternately, you can go for current limiting reactors to limit the fault current to less than that of the CB breaking capacity. But, then be careful about voltage drop in the reactors.
Good Answers: 164
11/20/2011 10:59 AM
Ampilfying my post a little, here is an oscillogram collection from LS Industrial Systems, whose Susol MCCBs (based on the rotary double-break design pioneered by Schneider Electric) are one of the fastest CBs in the world....1.3 milliseconds of clearing time on a prosepctive 150kA !!! (Please note the peak current let through)
Register to Reply 4 comments
electricalexpert65 (1); kvsridhar (2); SolarEagle (1)
