Previous in Forum: AC DC   Next in Forum: Current Transformer Rating
8 comments
Changing Options of Underloaded 160kw Motor?
11/20/2011 6:51 AM
In our company there is 160 kw motor running with star delta starter. Running load is 90A Pf .85 Voltage 426v Can I change this vaccum pump motor with 110kw motor.. Please guide dear friends......
Good Answers: 181
Re: Changing Options of Underloaded 160kw Motor?
11/20/2011 8:17 AM
It would seem to be over rated, but does it have any peak loads it has to handle?
11/20/2011 9:15 AM
no peak loads. Main motive is energy saving by smaller rating motor.
Good Answers: 170
11/20/2011 10:00 AM
But then why did they select a 160kW motor? Cushioning?
Good Answers: 804
11/20/2011 11:07 AM
Motors use only what they need to use, plus losses inside the motor. All you will save is the very slight difference in the losses, maybe a fraction of a percent of total consumption. The cost of the new motor must be compared to the energy savings in order to properly evaluate this. If it runs 24/7/365 it may be worth it, but if it runs intermittently, as vacuum pumps often do, the payback may be too long to be of immediate impact.
11/21/2011 3:37 AM
yes its running 24/7/365
Good Answers: 102
11/20/2011 11:59 PM
The smaller motor will run hotter and not save any energy.
11/21/2011 2:34 AM
They say at about 80% of the rated load the efficiency is maximum,so select accordingly
pnaban
11/21/2011 8:20 AM
In India at 415 V (how did you manage 426V?) 3 phase
The power consumption is sqrt(3)x415x90x0.85 = 55KW and even at 426V(?) is 56KW
At 165KW you are running the motor at approximately 33% Load. At this load though the efficiency could be a few percentage lower but I won't have expected a high 0.85 pf. A pf of 0.65 to 0.7 would have been more probable.
The basic question is still why this very highty overrated motor?
Though I am not much aware of the vacuum pump characteristic curves, may be under certain load conditions it might need that power.
Register to Reply 8 comments
Anonymous Poster (1); electricalexpert65 (1); JRaef (1); panju (2); pnaban (1); TonyS (1); Wal (1)
