Previous in Forum: Parallel Operation of Transformers   Next in Forum: The LED Revolution
Offset MHO Relay
11/21/2011 11:18 AM
Hi everybody,
I am having some queries regarding offset mho relay used in loss of field generator protection.
Here relay operation is based on Impedance Z.If calculated impedance and its angle enters the circle, relay issues trip.
Offset is distance from origin towards -X, which is normally set as -0.5 * X'd(Direct axis transient reactance).
Circle diameter is equal to direct axis synchronous reactance, Xd
It is clear that relay operation is based on impedance, which is measured in ohm.
Then why the protection named as offset mho ?
why not offset ohm.
Pl explain
Regards,
Arun
Re: Offset MHO Relay
11/21/2011 12:11 PM
11/21/2011 11:26 PM
Hi Lyn,
Impedance (Z) is calculated from resistance and impedance, where its unit is ohm
Admittance (Y) is calculated from conductance and susceptance, where its unit is mho/siemens
Here offset mho relay works on calculation of Impedance (Z).
Kindly clarify me
Thanks & Regards,
P.S.Arun kumar
11/21/2011 11:28 PM
Hi Lyn,
Kindly clarify me
Thanks & Regards,
P.S.Arun kumar
11/25/2011 11:00 AM
Hello all,
Pl clarify my doubt.
Regards,
Arun
Register to Reply 4 comments
