Previous in Forum: Bank Capacitor or Soft Starters   Next in Forum: Offset MHO Relay
11 comments
Parallel Operation of Transformers
11/21/2011 8:32 AM
Dear friends,
We do have two 66/33/15Kv transformers with a capacity of 12/16MVA (ONAN/ONAF) each, which can not operate in parallel due to greater impedance difference in the 15Kv side.
So, can the transformers operate parallely in the 33Kv side only, but with separate busbar for the 15Kv side?
Re: Parallel Operation of Transformers
11/21/2011 11:48 AM
If they were fed from the same 33kV source and not connected to the same downstream 15kV load, then they would not be operating in parallel; each transformer would not know of the other's existence, so to speak.
11/22/2011 12:23 AM
To make the question clear, the transformers are fed from a common 66KV busbar and our plan is to make them operate parallel only in the 33Kv side, but isolate the 15Kv bubar so that they will operate separately in the 15Kv side.
11/22/2011 2:14 AM
As far as I understand you a two transformers, 3 windings each, 66K k/33 kV/15 kV and you want to paralell them on the 66/33 kV but no parallel on the 15 kV side because of the impedance.
Overall, if the conditions are good for connecting them in parallel only between 66 kV and 33 kV then there is no problem. You can go ahead with it, just be careful not to accidentaly parallel them on the 15 kV side.
cheers
The time is ......now
11/22/2011 8:39 AM
That does make sense.
11/21/2011 12:20 PM
If the primary is fed from the same single source and if impedance matches, then momentary paralleling shall be done.
Good Answers: 170
11/22/2011 5:55 AM
Intriguing Question! What is the vector group of the transformer? What are the loads connected to the 33kV Side and to each of the 15kV Side? Are they feeding semiconductor loads by any chance?
11/22/2011 6:36 AM
the transformers have the same vector group of Ynd11d11 and the connected loads with each of the lines vary from household lighting to cement factories.
Good Answers: 170
11/23/2011 9:07 AM
If the loading on the unparalleled 15kV sides is unequal, then it could cause differential voltage drops in the two 15kV secondaries and thus would cause circulating currents between them. The transformer differential protection could spuriously trip.
11/23/2011 12:34 AM
On my experiences previously, it was the same issued; where vector Tx is same, different input of Tx, and output need to be merge out together without disturbing the transmission line. Base on simulation programme we'd identified the output is fluctuated base on load demand, what we suggesting is the process behaviour (output) should auto synchronised with impedance generated with load demand.
LifeCycle of Engineering
Good Answers: 102
11/23/2011 7:41 AM
What's the worst thing that could happen?
12/11/2011 12:37 PM
poof ,boom!
Register to Reply 11 comments
Anonymous Poster (1); chandru1982b4u (1); electricalexpert65 (2); khairul.asra (1); nikolay (1); PWSlack (2); tewanay (2); Wal (1)
