Previous in Forum: Harmonics and Fault Calculation Books.   Next in Forum: Rough Approximation of Power Transformer Required
India - Member - New Member
Reverse Direction Detect
11/23/2011 11:25 AM
In conveyor system forward rotating time speed sensor sense and reply to PLC conveyor is working normal. Found mechanical gearbox hold back system is failure in some time, that time conveyor got rotate towards reverse direction(inclined conveyors) automatically this will lead the problem at start and stop the conveyor. So I need to know when the conveyor is starting in reverse direction please give me idea to how to identify the probem and which sensor is best to detect this problem. Please give ur valuable comments.
Arun Babu
Re: Reverse Direction Detect
11/23/2011 11:43 AM
Wouldn't fixing the gearbox hold back system be the best solution?
Good Answers: 181
11/23/2011 4:26 PM
There are plenty of direction rotation sensors on the market, look on Google.
Good Answers: 120
11/23/2011 10:42 PM
Install a ratcheted reverse blocking cam clutches or bearings etc. These are common in industry. Get one you can turn off, in case you wish reverse operation in setup
cam clutches, etc
Per Ardua Ad Astra
11/24/2011 8:35 PM
If you have A plc controlling the conveyor, then you can use a quadrature encoder to indicate direction. I would suggest a motor brake to stop and or hold the conveyor.
repeat problems can not be solved by the same way of thinking ( A. Einstein)
Register to Reply 4 comments
aurizon (1); dthomas16 (1); PWSlack (1); TonyS (1)
