Previous in Forum: Fuse Rate   Next in Forum: Neutral CT
Fr.315L
11/24/2011 6:33 AM
Can anyone explain the term Fr.315L ?
I have seen it from related to the energy efficient motors.
"Two heads are better than one"
Re: Fr.315L
11/24/2011 6:40 AM
It is the motor Frame Number and has nothing to do with efficiency (It gives the motor capacity and mounting dimensions including shaft size and position)
Re: Fr.315L
11/24/2011 6:45 AM
Thank you.. Can you notify the motor capacity and mounting dimensions including shaft size and position for Fr.315L ?
Re: Fr.315L
11/24/2011 8:16 AM
It is going to be quite a bit detailed. If you can get hold of check IS 1231.
It has all the data that you need from table 1 to 4.
Re: Fr.315L
11/24/2011 8:24 AM
Thank you.. Can you provide reference for the IS 1231 standards with table ?
Good Answers: 170
Re: Fr.315L
11/24/2011 9:12 AM
Any motor manufacturer's catalogue would give you the details you want.
Anguraj Chelladurai (2); Anonymous Poster (2); electricalexpert65 (1)
