Previous in Forum: HP to CC Conversion   Next in Forum: Surface Area Calculation for Insulation Work
Formula for Bearing Clearance?
11/25/2011 10:08 AM
How can I calculate the internal clearance of bearing?
Re: formula for bearing clearance?
11/25/2011 10:17 AM
I'd look in a bearing design guide, ask my bearing supplier, look on-line at bearing supplier web sites or consult my copy of Machinerys Handbook.
11/25/2011 11:28 AM
It is something like this- Under actual running condition at the rated load, the roller bearings would work with a light pre-load (may be a few tens of microns). From there you must back calculate to the cold bench end-play
For Hydrodynamic journal bearings it is dependant on the oil film thickness that can carry the load without breaking and you don't land up under boundary lubrication condition.
Good Answers: 183
11/25/2011 11:52 AM
The first information which you did not give is the type of bearing! there are 1000 types of bearings which one you think about ?
As many other asking questions you believe we are wizards and able to read from far away your thoughts. We are not !!!!
As long as the information is not complete no consistent answer can be formulated.
THIS IS VALID for ALL who want a support.
Good Answers: 16
11/25/2011 11:55 AM
This depends on the type, size and physical location of the bearing. It also depends on your resources and knowledge.
If it is an easily accessible roller bearing you can check the un-loaded portion with a feeler gauge.
Its also very common to do a lift check... This involves the use of a dial indicator preloaded then set to 0. You would then lift (or jack) the equipment until the load is shifted from the loaded portion to the un-loaded portion, you then find the bearing clearance on the indicator.
However you need to be more specific, what equipment is this bearing on, what type of bearing, approximate ID / OD
Regards,
Tim
Re: Formula for Bearing Clearance?
11/26/2011 11:50 AM
First of all why do you want to calculate the clearance?
OK let us say you are able to calculate, what you will do with the calculated value.
So, you have to share the application, the size, the speed and the problem only then you will get some feedback.
Anonymous Poster (1); lyn (1); Mukesh0861 (1); nick name (1); Tim in Mexico (1)
