Previous in Forum: Formula for Bearing Clearance?   Next in Forum: daN/mm -- it's not what I thought!!!
Surface Area Calculation for Insulation Work
11/25/2011 11:46 AM
can you provide how to find the insulation surface area for pipe,vessels,fittings,valves. also inform the shall the measurement including the thickness of insulation?
Please help me.
Re: Surface Area Calculation for Insulation work
11/25/2011 12:42 PM
Start here:
How to Insulate Pipes : How-To : DIY Network
Hope this helps you.
11/26/2011 1:51 AM
Hi,
Would you clarify,u want to find out the the surface area of a certain thickness of insulation? is it required for cladding for example?
11/26/2011 10:39 AM
ONLY FOR FINDING THE SURFACE AREA OF VESSELS OR EQUIPMENTE TO BE INSULATED. SO PLS TELL THE FORMULA FOR ELLIPSOID,EQUADROID ETC..
ALSO FOR EXAMPLE IF WE ARE FINDING THE SURFACE ARESA FOR INSULATING 14 INCH 5 METER PIPE
SURFACE AREA = 2*3.14*14*25.4 *5*1000 SQMM
SO FOR CALCULATING THE SURFACE AREA, SHALL I TAKE 14 INCH OR 14 INCH + 50 MM (THICK. OF INSULATION) ?
11/28/2011 3:50 AM
Please:
  1. Turn off Caps Lock
  2. Refer to any engineering textbook that gives details of formulae needed to calculate shape areas.
11/26/2011 11:44 AM
Why you are not taking help of your service provider. Normally Insulation vendor have very good data book with them which have all the formulae and other relevent data for their service area.
11/26/2011 12:05 PM
Actually this is a very basic and simple formula.
First, what is the environment your pipe is being exposed to and how is the climate on a yearly average. Heat, cold, humidity and so on. Next you figure what type of materials you want to use, and using the manufacture of the type you should choose, find the "R" rating, thermal dynamics of your chose of materials.
Standard calculation of any surface is the basic area formula, linear surface area. And for the thickness, would be calculated as would be expected to suffice in what ever the most extream climate your piping is exposed too.
Calculation for linear surface area: Pi x Dia x length
Once you have your surface area, your thickness is determined by the tpe of material.
Hope this was a simple to follow as it was for me to explain.
Maximo
11/26/2011 11:31 PM
Hi,
You should take the outer diameter (pipe dia.+thickness). Normally insulation in your case is measured in square meters:
Insulation area : pi*(14+2)*25.4*5/1000
For vessels, also,consider the outer surface area.
For ordering the material don't forget to add about 5-10% extra to overcome the waste.
Good luck
Register to Reply 7 comments
Azat A. Rifat (2); binulal (1); LordMaximo (1); lyn (1); Mukesh0861 (1); PWSlack (1)
