Previous in Forum: Overload Relay   Next in Forum: High Power LEDs , Junction Temperature
Neutral Grounding Resistor
11/28/2011 9:40 AM
Whatever the equiments either alternator or transformer above 11000volts potential, star point neutral is earthed through a resistor,and the EF CT is located before the NGR. How does it limits the fault current from other equipments and whats the need for that. Also if one or two syncronised or operating in parallel found only one NGR closed out of 2, whats the need for two NGR's.
Good Answers: 181
Re: Neutral Grounding Resistor
11/28/2011 9:24 PM
Use the forum search utility. This subject has been covered many times.
Good Answers: 170
11/29/2011 4:29 AM
Too many questions in one post to answer. I suggest you attend to our two days' training on earthing.
Register to Reply 3 comments
Anonymous Poster (1); electricalexpert65 (1); TonyS (1)
