Previous in Forum: Cobalt Iron Laminations   Next in Forum: Neutral Grounding Resistor
Overload Relay
11/28/2011 4:59 AM
I want to the connection between an overload relay & 3 phase induction motor.
If the induction motor draws a FLA of 123A, what should be the rating of the overload relay?
Re: Overload relay
11/28/2011 5:26 AM
The correct overload relay will embrace the full load current of the motor within its range of available settings.
  • If it's larger, it might not trip before the motor burns out, so it will not fulfil its intended purpose.
  • If it's smaller, the motor will trip the overload before full load current is reached, which can be classed as "nuisance tripping".
India - Member - New Member
Good Answers: 164
Re: Overload relay
11/28/2011 5:55 AM
PWSlack's answer is comprehensive.
To probe a bit, at this power level, are you using DOL starting? Unusual, i may say. If you are using a ΥΔ starter for example, it is normal for the relay to be within the Δ, and you should set it to the phase current, ie., 123/√3 A.
Good Answers: 804
Re: Overload relay
11/28/2011 11:34 AM
"If you are using a ΥΔ starter for example, it is normal for the relay to be within the Δ, and you should set it to the phase current, ie., 123/√3 A."
Oooohh, I'll bet that confused him...
Good Answers: 164
Re: Overload relay
11/28/2011 8:41 PM
That was the general idea
Good Answers: 244
Re: Overload Relay
11/28/2011 11:13 PM
If you are in NEC (or CEC) world, the overload setting of the DOL starter motor is generally no more than 1.15% of the motor nameplate full load current.
Here is the maximum overload setting for continuous duty motors from NEC 430.32 (A)(1):
Motors with a marked service factor 1.15 or greater: 125% of nameplate full load current
Motors with a marked temperature rise 40°C or less: 125% nameplate full load current
All other motors: 115% nameplate full load current
I think PWSlack's comment is per IEC standard.
- MS
Re: Overload Relay
11/29/2011 3:16 AM
1.15%? Really?
Good Answers: 244
Re: Overload Relay
11/29/2011 8:08 PM
Thanks for pointing it out. I think, it is understood that 1.15% is a typo. It should be 115%.
- MS
Register to Reply 7 comments
JRaef (1); kvsridhar (2); msamad (2); PWSlack (2)
