Previous in Forum: Need a Supplier for a Metric Screw Please!   Next in Forum: Finding the Right Process for Bending Steel Flats to Parabolic Curve
9 comments
Heat Staking Parameters
11/29/2011 3:45 AM
Hi I am trying to find temperatures and pressures used in heat staking of 30% GF nylon 6. All I am getting so far is the general procedure and finished stake shapes.
Any literature source or guideline well be useful.
Thanks
Pathfinder Tags: heat staking nylon
Re: Heat Staking Parameters
11/29/2011 7:24 AM
Here's the material data sheet...
http://www.tamshell.com/mds-nylon6-30gf.htm
11/29/2011 7:52 AM
11/29/2011 8:03 AM
That's without filler. The glass is there to raise the heat deflection and melting temperature. Remember, glass doesn't melt or change viscosity.
OP, I suggest that before we confuse you too much that you contact the company that is supplying the resin and ask them.
11/29/2011 8:41 AM
12/01/2011 4:23 AM
This was a very useful link, thanks :)
11/29/2011 7:45 AM
480-510°F and 15-30PSI, if using heat only. If using ultrasonic energy it depends on many more factors.
11/29/2011 8:02 AM
Thanks for the values gives me a better idea of the capabilities.
there wont be any ultrasonic staking, just heat staking. These values did you know these through personal experience?
11/29/2011 12:43 PM
That's my recollection of 25 years ago.
I'd start with a heat controlled soldering iron and experiment with different temperatures. There are a lot of variables. You'll know when you get to the right temperature.
Is this manual or automated processs?
12/01/2011 4:22 AM
its going to be an automated process.
Thanks for the help :D
Register to Reply 9 comments
ankith32 (3); lyn (3); SolarEagle (3)
