Previous in Forum: Isolation Transformer   Next in Forum: Stepper Motor on Gas Generator
8 comments
Regarding Synchronous Generator
12/02/2011 9:22 AM
What will happen if a synchronous generator is run at a frequency other than the designed frequency, e.g. a 50 Hz generator is run at 60 Hz or 40 Hz.
Re: Regarding Synchronous Generator
12/02/2011 9:32 AM
Really now. Don't you have even an inkling of what will happen????
Do you know what a synchronous generator is????
The sounds like homework to me.
If you don't know the answer, take a guess.
12/02/2011 2:59 PM
They are known as synchronous generators because the speed of the rotor must always match the supply frequency.
12/03/2011 12:25 AM
The synchronous generator runs at synchronous speed only. ie., at synchronous frequenc.
"Two heads are better than one"
12/03/2011 9:26 AM
Well, it appears that there had been some misunderstanding. O.K.
I am posing the question like this.
What will happen if a synchronous alternator designed to operate at 50 Hz. is operated in synchronism with a 60 Hz. or 40 Hz. grid?
And yes, I know that synchronous generators run at sunchronous speed. Whatever. Thank you all for reminding me.
12/04/2011 3:41 AM
overspeed.... shutdown
12/05/2011 3:40 AM
...or underspeed shutdown.
12/04/2011 4:23 AM
Your original post too said the same so it didn't matter. Assuming the protections (speed like governers etc) are not in place or messed with and the generator is stand alone.
At lower frequencies - Efficiency would be just a bit lower.
At Higher frequencies- Along with above mechanical design aspect to be looked into.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
12/04/2011 7:22 PM
Ha..ha..ha..
I ever did this but pls take a really careful regarding the winding configuration, some may need to change accordingly, protection has to be readjust, and may be you will have the power degrade. Pls take a deep on the service manual
Regards
One system
Register to Reply 8 comments
Anguraj Chelladurai (1); Anonymous Poster (1); loadshare (1); lyn (1); PWSlack (1); Soumik Nath (1); visaseller (1); wareagle (1)
